Thanks for the answer.
Tried it on Sunday, does seem pretty good except when it hits waves, somewhat not as rigid as I hope. Also slight pool of water where the side hulls hit the main deck, near the center. I have tried the old Sportsman SUP before, which seems similar to the i11s in SUP form, very similar based on the stats and picture below. That one the PSI is a lot higher, almost 3 times. Would it be possible to pump the i11s higher than the recommended PSI or is that not recommended considering the construction is different?
One last question, do Hobie sell extra pads I could glue on? What is the part number for that? Thanks!
https://www.hobie.com/sups/outdoor-i-series/
