Click-n-Go with older drive causes lever release http://www.hobie.com/forums/viewtopic.php?f=60&t=12867 |
Author: | mmiller [ Tue Jun 23, 2009 10:37 am ] |
Post subject: | Click-n-Go with older drive causes lever release |
It is a potential problem to use an older drive in a newer Click-n-Go hull. Problem: The drum shaft in an older drive can rotate within the drive. The levers pinch the shaft and as the drive rocks... This can "ratchet" open the Click-n-Go lever and release the drive. The newer drives for the Click-n-Go lever system have splines to prevent this rotation. ![]() The shaft is easy to replace. Simply hammer out the old shaft with the new one. |
