http://www.hobie.com/forums/
MirageDrive ARC Crank Assembly
http://www.hobie.com/forums/viewtopic.php?f=60&t=61806
Page 1 of 1
Author:  mmiller [ Wed Nov 15, 2017 3:02 pm ]
Post subject:  MirageDrive ARC Crank Assembly
The screw that attaches the base of ARC cranks to the drums must be properly tensioned to hold the crank against the drum adjustment holes.
Tension the screws to add a moderate amount of friction to the fore and aft movement of the ARC cranks. A loose screw could allow the crank to move away from the adjustment holes and possibly strip the outer plastic away between adjustment holes.
The ARC crank drives use a 7/32” Allen Wrench.
http://www.phpbb.com/
