http://www.hobie.com/forums/
Roller Furler Jib
http://www.hobie.com/forums/viewtopic.php?f=69&t=20991
Page 3 of 6
Author:  van lee [ Thu Feb 25, 2010 9:41 am ]
Post subject:  Re: Roller Furler Jib
Hi Sterling,
I am new to the AI forum and found your feedback on installing a furling jib very refreshing, creative and innovative!
I live in San Diego where the winds most of the time are 5 to 8 knots so adding a jib would be exciting.
Will you have a parts list and step by step directions for novices?
All the best,
Van
Author:  S.Yoars [ Thu Feb 25, 2010 6:47 pm ]
van lee wrote:
Hi Sterling,
All the best,
Van
Hi Van!
thank you for the positive feedback
as for a parts list ive been working on it for a few days now in between work and college work so here is what i have come up with (the store names at the top is where i got the parts at the request of timo)
West Marine
2 - harken micro block single pulleys
2 - fairleads
2 - v-cleats
2 - swivel snap hooks
4 -1½ inch shackles
Lowes
1 piece of ¾ inch pvc pipe 8 ft. long -------for furler mechanism
1 ¾ inch to 3 inch pvc adaptor ----------------for furler mechanism
1 piece of 1 inch pvc 11 inch long -------------for mast tube base reinforcement
5-6 tubes of Loctite 50 minute Marine epoxy
2 - 1inch hose clamps
3 – 7 to 9 inch turnbuckles
4 – 1½ wall hooks
2 – flush mount hose brackets
Screws and bolts for:
v-cleat, fairleads, wall hooks, flush mount hose brackets, chrome pad eyes
Kayak shop
2 -14ft sections of steel kayak rudder cable
30ft of 6-7mm accessory cord --------------for jib sheet
10ft of 6-7mm accessory cord --------------for jib reefing line
10ft of 6-7mm accessory cord---------------for jib halyard
2 double sided carabineers---to attach the steel kayak rudder cables as stays easily
Hobie
Small kayak sail kit (complete)
Mast base
2 - Chrome pad eyes
i did not include all the individual screws and bolts that i used to attach everything together because some of the parts you may get may take a different size screw or bolt or require a different number of them.
all the screws and bolts i used were stainless steel though
as for step by step instructions most of the steps are covered in this forum but if i have time in between school and work i will try to post a "guideline" to help you follow along with the steps 8)
I hope this helps!!
Author:  S.Yoars [ Sun Feb 28, 2010 5:19 pm ]
timo wrote:
Sterling,
Thanks as always for the information! Sometime can you post a pic of the top of the mast with its clamp for attaching the stays? As well, can you clarify the mechanism and construction of the furler?
here is the top of the mast timo
sorry it took so long
Author:  S.Yoars [ Sun Feb 28, 2010 5:35 pm ]
timo wrote:
Sterling,
and here are the pictures of the furler "mechanism" (its really simple, so i wouldn't really call it a mechanism :lol: )
the first picture is what it looks like when the jib is flying and the rest are of what it looks like when the jib is reefed.
i also took pictures of the shackle underneath, this is how i attach the jib to the bow pad eye where the handle is.
and i tension the whole set up but adjusting the truckers hitch (the knot the shackle runs through) so that it is tight once i attach the shackle to the bow pad eye
Author:  okz00k [ Sun Feb 28, 2010 6:07 pm ]
Thanks for such a comprehensive description of your outstanding jib design.
Det
Author:  S.Yoars [ Sun Feb 28, 2010 6:26 pm ]
no problem Det!
im just glad that people like i!! :D
Author:  timo [ Sun Feb 28, 2010 9:00 pm ]
Sterling,
Great pics of the mast head connections and the furling system. I'm very impressed at the ingenuity in this. Hopefully I'll have my mast and spare hatch cover in a week more. Looking forward to getting started on this project!
Hope your exams didn't get in the way of your sailing.
Thanks very much!
Author:  S.Yoars [ Mon Mar 01, 2010 7:55 pm ]
Hhahahahah thanks timo!
Good luck on your jib as your parts start to trickle in ;)
Author:  Chekika [ Tue Mar 02, 2010 7:29 am ]
Yes, Sterling, it looks like an excellent design and implementation. Very well done!
Author:  S.Yoars [ Tue Mar 02, 2010 7:40 am ]
thanks Keith! :D
Author:  timo [ Sat Mar 06, 2010 6:04 pm ]
Sterling,
The Hobie parts order arrived and we're off and running on our jib building project. Look out: here begins the questions! First, your parts list specified an 8 ft length of 1 inch pvc pipe to support the jib. Is it possible that the pipe should be a little longer than 8 ft? Perhaps 9ft? We cut a length to 8 ft but when we inserted it into the jib sleeve it appeared to be about 8 inches or a foot short of filling the entire sleeve.
Second, the parts list listed a "flush mount hose bracket". The Lowes guy showed us a bunch of them in different sizes. Can you tell which size we need?
(More to come -- run for your life.)
Thanks!
Tim
Author:  S.Yoars [ Sat Mar 06, 2010 6:18 pm ]
Timo,
the Sleeve is definatly longer than the pipe. I just cut the PVC short to prevent any possible damage to the end of the sleeve
as for the hose clamp, about 1/4 inch is the size I have but any size that will fit the turn buckles will be fine. Be sure to get the thickest you can ( which may require getting a bigger size) but any that are big enough to fit the turn buckle will work well.
Be sure to post pics when your finished!! :)
Author:  timo [ Sat Mar 06, 2010 8:43 pm ]
Sterling,
This is kind of basic but as I said at the onset, it is probably a stretch to say evern that I'm not much of a DIY person: any tips on the kinds of thru-the-hull fasteners you used for the attachment points of the mast receiver/turnbuckle/hook connectors, and for the pad eyes? Stainless steel nuts and bolts yes? With those nuts with nylon in them? Not screws? What length to go through the hatch cover? I'm assuming they are about a half inch long stainless stell bolts with washers and nylon nuts and coated with marine goop for the seal (never done that before but that's what one does right?). Does that sound right?
Is there any reason you put the pad eyes on the Hobie parts list? Pad eyes are pad eyes, right? I forgot to order them from Hobie but I assume I could get equivalent pad eyes at west marine?
You should charge for this course.
Yeah spring is in the air up here in upstate NY. Hope to get this together to launch within the next two weeks for the first sail of the year. Provided I don't screw this up and mount the sail backwards and upside down I will certainly post pictures.
Thanks!
Author:  S.Yoars [ Sat Mar 06, 2010 8:48 pm ]
Timo
you are exactly correct the best way to attach most hardware (that you can get inside to put a bolt on) is to use bolts. Use all stainless machine screws with the nylon bolts and washers
As for the pad eyes from Hobie, they are made of chrome and are very strong, but you can find stainless or chrome ones at west marine.
Let me know how it goes!! :)
Author:  timo [ Mon Mar 08, 2010 9:31 pm ]
Sterling,
I'm having some trouble finding a 3/4 to 3in pvc adapter. Is it possible that I have the sizes wrong or that the furler mchantism is formed of some kind of adapter plus some other pvc coupling parts? Regardless, what I'm after is something that attached the end of the 8ft 3/4in pvc pipe to a drum-like pcv fitting, probably 3 inches in diameter, right? How about the inside of the 3in part -- it is completely open space or is there some more complicated structure (I've seen these drum like parts both open space and filled).
Thanks!
Page 3 of 6 All times are UTC - 8 hours [ DST ]
http://www.phpbb.com/
