It is currently Mon Jun 26, 2017 1:03 pm
PostPosted: Mon Jun 14, 2010 1:54 am
i have this ram mount holder
and i want to install it on my AI
i need to change the ball mount to something like this :
can you give me the correct part ? :wink:
PostPosted: Mon Jun 14, 2010 4:14 pm
See http://macleanoutdoors.net.au/index.php ... strap.html.
"RAM-108BU RAM 'C' base with ball & strap. 1.5" ball attaches to 1/2 - 2" tubes (such as Hobie Island crossbars & akas)"
HTH :)
PostPosted: Fri Jun 18, 2010 7:32 am
HTH :)
I prefer U-Bolt Pipe Mounting
PostPosted: Sat Jun 19, 2010 2:59 am
There's one pictured in the new 2009-10 Hobie parts catalog. Page 18.
UBOLT RAIL BASE 1''
#72023017
Hobie should know where this will fit.
PostPosted: Sat Jun 19, 2010 1:34 pm
UBOLT RAIL BASE 1''
#72023017
And of course need to be
1.5" ball.
PostPosted: Sat Jul 03, 2010 12:29 pm
Many things can be attached by making your own mounts. 1.5" PVC pipe can be cut in 2-4 inch sections. Then cut a section out of the pipe and you have a C shaped piece that will snap onto the AKA tubes. Check it out!
PostPosted: Sat Jul 03, 2010 11:43 pm
I am looking for a RAM mounting solution for the rear AKAs as well. I want to put spinning poles about 1/2 way out, w angled rod holders to achieve maximum line separation.
Does anyone have pictures or suggested parts #s for this?
Ideally it would be a low profile, strap-on or Ubolt mount, w 1.5" rubber ball that would not impede the use of the tramps when fishing or recreating. Like this:
http://www.themountdepot.com/RAM_108BU_p/ram-108bu.htm
Does anyone know the exact diameter of the AKA bars? I guesstimate 1 3/4".
PostPosted: Tue Jul 13, 2010 6:40 am
do you think the 108b would work ?
i looked at these but thought they would just spin eventually with the weight of the rod (and hopefully fish)
PostPosted: Wed Jul 14, 2010 2:56 am
Barely. It does not look sturdy. For a camera mount it might be fine.
I am hoping for something better than a pipe clamp with a rubber sleeve. A u-bolt would be better when things get knocked around.
Maybe another brand?
PostPosted: Thu Jul 15, 2010 2:45 am
emailed ram with the problem, in the mean time i've ordered 2 x 202-225 which have a (2x2.5)" base.
I'll source some ubolts and fit them, if it's a tidy job i'll post pics.....
If not u'll never hear from me again :lol: :roll: :lol:
p.s. what is the exact dia of the metalwork on the ai ?....need to source u bolts and allow for powder coating.
PostPosted: Fri Jul 16, 2010 3:35 am
These are crazy expensive, but should do it = 1 7/8"
http://www.ram-mount.com/CatalogResults ... fault.aspx
or the larger 2"
Yours is much cheaper- let us know what u-bolt fits.
http://www.ram-ount.com/CatalogResults/ ... fault.aspx
Now to pick the rod holders.
Damn. No help from Hobie. :(
PostPosted: Fri Jul 16, 2010 3:40 am
the ram 117's are great, i used these on my t15.
PostPosted: Fri Jul 23, 2010 7:16 am
any luck???
PostPosted: Fri Jul 23, 2010 1:22 pm
Did you get them yet??
BTW, a friend told me yesterday that the measurements are 1 5/8" on the outside of the bars. I would guess this is at the most circular point.
