http://www.hobie.com/forums/
AI Tramps on a TI
http://www.hobie.com/forums/viewtopic.php?f=69&t=26107
Page 1 of 2
Author:  stringy [ Tue Jun 08, 2010 1:10 am ]
Post subject:  AI Tramps on a TI
I was hoping to fit AI tramps on a TI. The AI tramps are slightly longer and even with the straps done right up the tramp wasn't as tight as a drum as it should be.
Slipping some pvc pipe in the sleeve forward of the aka gets rid of the slack and the straps can be correctly tightened.
I had some 42mm pipe at hand and that was an easy fit. Cut it into two sections as seen in the pic.
Removing the small section near the aka joint allows you to fold the ama in when the tramps are rolled around the aka. :)
Author:  Slaughter [ Tue Jun 08, 2010 11:57 pm ]
Post subject:  Re: AI Tramps on a TI
How good does that look mate ? Very impressed. Have you taken it for a blast yet ?
Author:  stringy [ Wed Jun 09, 2010 1:13 am ]
Whoa! Chill out dude! Plenty of time for that. I'm so relaxed I don't feel like doing anything at the moment.
Those Hobie pine cones are the best stuff ever! :D :D :D
No I haven't. :( Still sorting out trailer and avoiding 30 knot westerly's
Author:  Slaughter [ Wed Jun 09, 2010 2:44 am ]
That TI-tree joke probably sounded funny after some pine cones didn't it ? :roll:
Author:  stringy [ Wed Jun 09, 2010 5:07 am ]
I'm still laughing! :lol: :lol: :lol:
Author:  Honu [ Fri Jul 09, 2010 4:42 am ]
That's a great fix to make the AI tramp fit the TI.
Any concern about the PVC pipe scratching up the black paint on the akas ?
Author:  stringy [ Fri Jul 09, 2010 5:03 pm ]
G'Day Honu,
So far no signs of paint scratching but I guess it could occur.
I don't think it would be much worse than the actual tramp though. If you're worried you could wrap the pipe with towelling or foam.
If the TI bars are anything like the AI bars then scratching will be the least of your problems. :wink:
On my AI's the coating blisters by itself. In fact where it is scratched it seems to corrode less! :?
With my TI I have sprayed Lanox over all the bars. It leaves a protective residue which I hope will lessen the corrosion.
Time will tell if it works! :)
PS- There is room for larger PVC pipe on the aka. I'm going to try some 50mm next.
Author:  Honu [ Fri Jul 09, 2010 5:55 pm ]
Thanks Stringy. I'm heading to Home Depot this weekend.
Author:  Paul67 [ Fri Jul 09, 2010 6:28 pm ]
I just googled Lanox and hove found it is a lubricant. Does this make the bars slippery/sticky, does it collect sand/dust more?
Excuse these questions but I have never seen this product.
Author:  Cowsgomoo [ Sat Jul 10, 2010 3:11 am ]
Lanox is great stuff. I use it on all the metal bits. I hang the aka's from the clothes line, give them a quick spray then wipe them down. Leave them to dry a little. I don't get anything sticking to them. Just don't use it around New Zealanders...
Author:  Paul67 [ Sat Jul 10, 2010 3:12 pm ]
Thanks for that, will have to get some then, as for the NZ's, I have 1 next door. I might just get his wife to take him on a trip to a sheep farm, that way he will leave my TI alone. :wink: :lol: :lol:
Author:  Roadrunner [ Sat Jul 10, 2010 8:40 pm ]
Great idea! Have you had any problem with the pipes slipping out of position, especially with the Lanox?
I understand Lanox is quite versatile. Have you tried it on the pine nuts? :lol:
Author:  stringy [ Sat Jul 10, 2010 10:18 pm ]
:lol: :lol: :lol:
The pipe can slip if the tramps aren't tensioned tight enough. On our first trip one pipe rolled around and under the aka as I didn't have enough tension on it. Once tightened properly, they stay in place.
I thought the larger diameter pipe should solve that problem! :wink:
Author:  stringy [ Tue Jul 13, 2010 2:53 am ]
Just got back from our longest trip yet. Still only light winds but at least we were mostly sailing. I tried 50mm pvc pipe this time. It's a better fit and stayed in place, even with me hiking out. The TI is much better than the AI when sitting/reclining on the tramps as you are much higher and drier.
No backside dragging in the water, which is just as well as it's the middle of winter here. :wink:
PS-There is room for a larger pipe than 50mm, possibly one or two sizes larger at least.
Author:  Honu [ Tue Jul 13, 2010 9:03 pm ]
Thanks for passing on the field test results.
Page 1 of 2 All times are UTC - 8 hours [ DST ]
http://www.phpbb.com/
