It is currently Thu Oct 22, 2020 7:42 pm
PostPosted: Tue Aug 31, 2010 9:49 pm
I've only gotten out with it once, on a mostly windless day, so not much of a report yet, but here's a picture of my new fishing 1/2 tramp.
It can hold my fishing gear and my full weight with no trouble. And makes setup even quicker.
http://KayakingBob.com - - - - - - - - - - Hobie Island Sailing since 2006 - - - - - - - - - - SpraySkirts
PostPosted: Wed Sep 01, 2010 12:37 am
Tight! A place for everything, everything in its place.
Is that a Kagi on the right?
Fish don't stand a chance.
The Wind Is Your Friend...
PostPosted: Wed Sep 01, 2010 1:42 am
Nice!
Mitch
    2010 Tandem Island
    2010 Revolution
My sailing blog
Our sailing videos
PostPosted: Wed Sep 01, 2010 2:11 am
Hobie Team Member
Bob
Very nice job.
I had something similar in PVC, but left it somewhere? :roll:
Making new one out of ABS due to floatation capability.
Can you give dimensions of yours?
Mahalo
Dan
PostPosted: Wed Sep 01, 2010 12:32 pm
Nice! Looks like you can rig it up preloaded with gear for a speedy setup.
c2y
PostPosted: Wed Sep 01, 2010 1:20 pm
Very impressive Bob. And if you are ever in a remote spot and meet with an unfortunate incident, the paramedics can use it to carry you out.
PostPosted: Wed Sep 01, 2010 1:23 pm
reconlon wrote:
I've only gotten out with it once, on a mostly windless day, Image
OOOOh so you rig it up vertically like a jib as shown. I need to see that one. :lol: :lol: :lol:
no really Bob, how is it attached to the AKAs
http://s909.photobucket.com/albums/ac294/gsammy925/
PostPosted: Wed Sep 01, 2010 2:01 pm
NOHUHU wrote:
Tight! A place for everything, everything in its place. Is that a Kagi on the right?
Yep my Kage in it's PVC sheath (so I don't stab myself). :o Been carrying it for a couple of months, and finally got to use it on the shibi, one strike, and it was all over!
They angle slightly, narrower in the front, so I can paddle over it. 22-23" wide, and 66" long (all measurements outside to outside of the pipes). The long "pipes" are from windsurf masts, and are very strong. The cross pieces, just PVC (sch 40) as they mainly are taking compression force. It's light, under 10# I was going to make the cross-braces quickly removable, but it's so much stronger with them under tension and bolted. Still wouldn't take more than 5 min. to disassemble. I left a few inches of the masts still on the front, so If I feel I need to expand it, I can add a "nose" to it easily.
Yep! Everything can get set the night before and just dropped on the aka and Velcro'd on. The kagi, gaff and club live on it all the time. Saves at least 10 min. of setup time, not worrying where everything goes at 5am. :)
I have a mesh bag with a drawstring that I added 2 grommets on the bottom and a loop on the top back that clips in (3 points) and covers the back (or bottom) 3rd of the tramp, which makes it easy to keep light and extra stuff I might bring secure, without having to tether everything separately. As I use lures, and jigs, I rinse them quick in fresh water and put in a ziploc bag for easy later cleanup. Same with gear like flashlights, headlights, etc. in another ziploc so no need to clean unless they get splashed before sunrise. Same with any trash.
JesseJ and I have talked about that. I'm hoping I'll just need it to carry to the truck, BIG FISH! :)
I used double-sided 3/4" Velcro on the 4 corners where the tramp pipes and the aka meet. Never failed me on the old tramp.
I likes how my old tramp fit, so this one is mainly a little bigger and much stronger. I can still reach under it to access the water or the gunnel area of the hull. I'm next working on a fish bag that will securely attach to the tramp to hold my catch. I'm using a simple make-shift one now to figure out what works best.
PostPosted: Wed Sep 01, 2010 6:27 pm
Well I would love to see the setup Bob. i was also wanting to inquire if I can get6 a custom sew job on my tramps. underneath,,3 straps sew in that have metal buckles. I'll mail and diagram. If interested
PostPosted: Wed Sep 01, 2010 7:34 pm
Hobie Team Member
Be sure to have something to attach 2 pool noodles lengthwise on side pieces so your big !00 lb ahi has it's own tow sled. :mrgreen:
PostPosted: Sat Sep 11, 2010 11:38 am
Haha, so many good ideas in this thread! I saw the PVC sheath for the kagi, and was like, "damn, why didn't I think of that :)"
PostPosted: Sat Sep 11, 2010 12:22 pm
Thanks! It works great keeping it protected, (or me protected from it) but I can still release it with one hand. I release the Velcro around the middle, then push the whole assembly (kage and sheath) forward which releases the back end and then can release it from the sheath. 1 second and it's in my hand.
When put away, no movement even it rough water. I worried how to protect the tip as it is probably sharper than my knife. It went right through the head of the 27# shibi on my first strike. Bled out in a couple of seconds.
PostPosted: Fri Sep 17, 2010 3:55 am
Bob could you post a picture of it mounted on your yak Please.
Regards Nick
