It is currently Wed Apr 24, 2024 2:28 pm
PostPosted: Mon Aug 15, 2011 9:07 am
I have been using one of the Shurehold paddles as a replacement for the stock Hobie kayak paddles that came with our i14t and TI. The Shurehold thing is basically a telescoping rod with a bunch of available options to snap onto the end. Boat hook, gaff, scrub brush, and a stiff paddle. I didn't buy the Shurehold for this boat, but had it left over from a power boat. I discovered I liked the stiff, straight single blade a lot more than the flexible stock double blade. You can telescope it out and use it to fend off rocks, etc. It makes a good emergency rudder.
Saturday we were out in light winds ( 12-14 kts.) and had a nice long downwind run coming back. I wedged the paddle under the clew and the rubber handle into the drink holder, and noticed we picked up about a knot or more of speed, and the sail stabilized and quit flopping around and trying to gybe . Didn't have the GPS with us so I can't give you numbers, but we went from quitely coasting down wind to making water rushing noises down wind, and picked up enough speed to surf down some small waves.
I had one more click out on the extension, could have gone another couple feet out if needed.
Just thought I would pass it along. I plan to replace our other paddle with another one of these, and to cut a smooth little V notch in the paddle so it holds the sail out a little more securely, and could be used to hold a line too.
http://2gringos.blogspot.com/
PostPosted: Mon Aug 15, 2011 10:02 am
Nice idea - thanks for sharing!
PostPosted: Mon Aug 15, 2011 11:06 pm
I've been using a telescopic boat-hook for exactly the same thing :)
works great!
PostPosted: Tue Aug 16, 2011 9:42 am
There's a boat hook attachment to this setup. I don't have it. But I really like the paddle.
