It is currently Thu Jun 22, 2017 12:33 pm
PostPosted: Wed Dec 28, 2011 9:22 pm
hey,
needed to remove several fittings so i could improve my aka bungees.
i cut a 3/4" deep socket with an angle grinder and a cut off wheel.
works great and cheap
cheers!
j
the TI3 rear ama mod
PostPosted: Thu Dec 29, 2011 4:55 pm
Nice job !
Jim
Clearwater, Fl
PostPosted: Wed Mar 14, 2012 10:23 am
Long nose pliers work well
PostPosted: Wed Mar 14, 2012 10:51 am
Hobie Tech / Moderator
Just an FYI - we offer a tool through our catalog do remove fittings - part # 71115101 $6.99 retail.
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Wed Mar 14, 2012 11:53 am
The Hobie tool is nice, but requires a bit of hand fitting to get it to really work well. It's a bit too wide and blunt on the edge of the pins. Although, it's probably a better starting point than a socket.
But, still nice a job on the too. Very well done and being able to use it in a socket wrench is a nice idea.
PostPosted: Wed Mar 14, 2012 4:30 pm
I initially used pliers to take the first one off but there is quite a bit of plastic cuttings in the threads of my boat, so some fittings are extremely hard to take off. After the pliers slipped once, I knew I needed something better.
I needed:
1 a deep throat to fit the extra bungee thickness
2 space for one hand to press straight down and steady the tool
3 lots of torque, controllable torque
4 high strength
5 very precise fit
A socket seemed to fit all of these.
J
PostPosted: Thu Apr 05, 2012 7:19 pm
nice work, ....on the eyelets i just use a screw driver thru the eye like a t handle and twist it off and on the T ones a simple pair of pliers ( or locking ones) to grip and twist off
2011 Hobie Pro Angler - Papaya
2012 Hobie Tandem Island - Papaya
PostPosted: Thu Apr 05, 2012 9:00 pm
I like it. Keeping my eyes open for a old socket now...
PostPosted: Fri Apr 06, 2012 9:04 am
Cowsgomoo wrote:
I like it. Keeping my open for a old socket now...
Thanks!
Just a fyi: I used an angle grinder with a cut off wheel to cut the socket, the steel is hardened. A hacksaw won't touch it.
Cheers,
J
PostPosted: Fri Apr 06, 2012 6:51 pm
I like the idea of the socket tool as well, nice work Km7. 8)
I have the Hobie tool and it is a bit awkward to use- especially if the fittings are tight.
I'm thinking I should grind a slot into an old socket so the Hobie tool fits - saves a lot of delicate grinding work.
Thanks for the idea. :)
PostPosted: Sun Apr 08, 2012 9:46 pm
I just changed the bungees on my amas and I used a pair of needle nose pliers. I scuffed a few of them up a bit. I'm glad you posted this. I think next time I'll cut up a socket. The Hobie tool looks like it would work but some of mine were pretty tight so I think it would be just as difficult with the Hobie tool. Thanks for the post, looks like a good idea.
Hey guys check this out!
www.adventureislanders.com
"Riding The Island Wind" RIPIT (Tim)
'08 Red Hibiscus AI w/2013 replacement hull, Lovin' it!!!
'11 Golden Papaya AI (for a chap)
'11 Tarpon 160
'14 Pro Angler 12
Users browsing this forum: No registered users and 7 guests
