3:1 sheet retaining two seat operation http://www.hobie.com/forums/viewtopic.php?f=69&t=46570 |
Author: | Chopcat [ Mon Feb 18, 2013 2:54 pm ] |
Post subject: | 3:1 sheet retaining two seat operation |
Has anyone done it? Cc |
Author: | kayakman7 [ Mon Feb 18, 2013 3:49 pm ] |
Post subject: | Re: 3:1 sheet retaining two seat operation |
Yes. Replace the double pulley at the stern with a triple and move the double to the end of the sheet. Reeve the line from the rear cam to the cheek block to triple to double to triple to double to triple to cheek to front cam. It will take some experimenting to get the best running lines and you will need a longer sheet. |
Author: | NOHUHU [ Mon Feb 18, 2013 3:56 pm ] |
kayakman7 wrote: Replace the double pulley at the stern with a triple and move the double to the end of the sheet. Reeve the line from the rear cam to the cheek block to triple to double to triple to double to triple to cheek to front cam. Simple. And don't forget to convert everything to metric.
Author: | Tom Kirkman [ Mon Feb 18, 2013 4:56 pm ] |
Just switch to a single 3 to 1 system. It can operated from either the front or rear seat. No need for two separate lines. |
Author: | kayakman7 [ Mon Feb 18, 2013 6:32 pm ] |
NOHUHU wrote: kayakman7 wrote: Replace the double pulley at the stern with a triple and move the double to the end of the sheet. Reeve the line from the rear cam to the cheek block to triple to double to triple to double to triple to cheek to front cam. Simple. And don't forget to convert everything to metric. Lol |
Author: | Chopcat [ Mon Feb 18, 2013 8:03 pm ] |
I shall be getting out my British Imperial ruler (for measuring and not the Queen) and getting a triple block so that Mrs cc can share the sailing. I might have to order without having the boat to hand. does anyone have an idea of how long a sheet i will need for the 3:1 two seat option? 8mm i presume (in good new English measurements) Cc |
