It is currently Tue Jan 16, 2018 9:20 pm
PostPosted: Fri Jun 21, 2013 12:21 am
Hi All,
Not sure if this has been done before, but what the heck!
I was looking for a way to prevent the rear of the AMAS from dragging on the ground
while wheeling my A.I from my house to the local beach. One of the simplest solutions
was to use a webbing strap to lift-and-support the rear of the AMAS.
I used a 2.2m length of 50mm nylon webbing and added a heavy-duty side-release clip
and a couple of webbing slides to keep the excess neat and tidy.
It sits over the rear of the hull, then each end goes around the outside of the AMAS, then
over the top (threading under the AKAS) to be clipped together on top of the hull.
I've used it on a number of occasions and it works very well. It certainly helps to remove
the strain on the knuckle joints (due to the AMAS hanging off them).
Obviously this design can also add a bit of extra stress on the front knuckle-joints, so
I'm going to make up another strap to go around the front of the AMAS.
I also have a another design, which uses lengths of dowel to provide the support, but it's
not quite as nice as this one.
Hopefully this is useful to other forum members... :-)
Cheers,
Mike.
PostPosted: Fri Jun 21, 2013 3:49 am
nice idea.
i have some strapping so will have a go
CC
May the odds be ever in your favor..
PostPosted: Fri Jun 21, 2013 2:45 pm
Man, that boat looks new, Mingle. You need to sail harder! :wink:
PostPosted: Fri Jun 21, 2013 11:12 pm
Tell me about it! I think it's down to a few things:
1: The original owner sailed it even fewer times than me.
2: I'm lucky to hit the water 5 or 6 times per year!
3: I spend an hour washing and inoxxing the entire rig after each trip...
Cheers,
Mike.
PostPosted: Sat Jun 22, 2013 12:08 am
And I know you were lusting after one for some time. Really looks great.
At least, at this pace, she should last forever. Cheers!
