It is currently Tue Apr 23, 2024 6:32 am
PostPosted: Sat Mar 18, 2017 5:49 pm
I have setup my main sheet to 3:1 and there is a lot of excess rope. I sail from the rear seat and my wife doesn't want to sail at all. I am contemplating on cutting my main sheet shorter. Is that a good idea? Anyone else where who has shorten their main sheet?
PostPosted: Sun Mar 19, 2017 4:05 am
It has been awhile since I set mine up for backseat-only sailing. I may have cut the main sheet. Not a big problem. You can always buy a new main sheet if you go back to the original set up.
PostPosted: Sun Mar 19, 2017 5:13 am
Thanks Keith. I'm going to cut mine.
Sent from my XT1585 using Tapatalk
PostPosted: Sun Mar 19, 2017 5:45 pm
Another issue I ran into today as I was sailing is that the factory furling line is too short to run it to the back seat of the TI. Any of you gentlemen swap out the furling line to another line that is longer? Also, the stock placement of the cleat for the furling line in the front is unnecessary and needs to be swapped for a block; afterwards, use the stock cleat and mount it next to the main sheet cleat in the rear (sailing from the rear seat only). As this is my second time on the water, I am learning as I go. So thank you for your patience and please don't flame me to hard. :D
PostPosted: Mon Mar 20, 2017 1:16 am
So, here is where that extra length on the main sheet comes in handy. I sail from the back with a 3:1 rig. I put a figure eight knot on the end of both the main sheet and the Furling line and the tie them together using a sheep bend knot. That gives me ready access to the furling line and only one rope to handle. Simples.
Terry
SE Queensland, AU
TI owner since 2014; sailor since I was a kid.
PostPosted: Tue Aug 08, 2017 3:11 pm
I do something similar when sailing solo from the rear seat. I keep a stern line tied on for docking, etc., and I just tie the loose end of the stern line to the end of the reef line to give myself the extra length to furl the sail from the rear seat. When the sail is furled and I'm coming in to the dock, I just untie the lines and I'm all set.
PostPosted: Tue Aug 08, 2017 5:25 pm
I just hate loose tangles of lines in the kayak. Lose rope and barbed fishinghooks dont mix well! :(
So I am planning to setup two automatic dispensing spools (for laundry line) that I hope wil, take care of the problem.
One for the main sheet and one for the furl line.
Kinda crazy huh? Well thats just me! :D
I will let you know how/if it works.
http://www.partridgeshadleigh.co.uk/lau ... 3103086166
Sailing my TI and fishing.... thats bliss!!
