http://www.hobie.com/forums/
Need help with aka issue
http://www.hobie.com/forums/viewtopic.php?f=69&t=64006
Page 1 of 1
Author:  tulsaturbo [ Thu Nov 29, 2018 6:58 pm ]
Post subject:  Need help with aka issue
I need a little help... Recently I ordered a fwd and rear aka as well as a ama for a mod that I'm doing to my PA14. I finally got around to start assembling it after receiving the parts a few weeks ago. When I went to put it together I noticed that the fwd aka (the top ring) extended above the ama although the tip was fully seated inside the ama. Did they build this wrong? No issues with the rear aka. I have attached some images. The ama is a 2014 model and the akas are 2015 models.
Author:  Hogman [ Thu Nov 29, 2018 9:44 pm ]
Post subject:  Re: Need help with aka issue
The 2015 amas are deeper than the 2014 amas. You need pre 2015 akas to fit the 2014 amas.
Author:  tulsaturbo [ Fri Nov 30, 2018 7:20 am ]
Thanks for the reply Hogman! :)
Do you know if Hobie sells the stainless rivets used on the akas or would you happen to know the size? I'm thinking to relocate it to where it should be for the ama I'm using.
Author:  mmiller [ Fri Nov 30, 2018 3:18 pm ]
A 3/16" x 1/4" grip rivet should be perfect.
8010181 RIVET POP 3/16x1/4 PH
Author:  tulsaturbo [ Fri Nov 30, 2018 5:59 pm ]
Thank you sir! :)
http://www.phpbb.com/
