It is currently Thu Nov 23, 2017 9:07 pm
 Post subject: Instant "Barber Pole"
PostPosted: Wed Dec 12, 2007 7:42 pm
Hobie Team Member
Finally got out in my AI conversion.
Thanks to all who helped me with advice. While playing around I discovered...Instant "Barber Pole". Doesn't require any additional bungie, or whatever.
It's built into the yaku. Just slip the main sheet over the cross member holder.
Caution. This was in a light wind.
Had previous done this with Sidekick slipping sheet under the yaku tips.
Aloha
Dan
PostPosted: Wed Dec 12, 2007 8:31 pm
CONGRATS! on finally getting ALL the parts!
:D
You should post (in between sailing) your thoughts on the conversion, and any new AI changes. In your picture, I see a new paddle holder, and it looks like a bolt connecting the aka to the cross brace instead of a pin.
Happy sailing!
Kayaking Bob
PostPosted: Wed Dec 12, 2007 9:07 pm
Hobie Team Member
Aloha Bob
Yeah it's a relief.
Your right on the bolt. See the other thread on the kit.
The rear paddle holder is probably a part you can order. Just requires a slightly longer bolt. The front blade holder is just cloth covered bungie with the ends folded under and screwed in along with a washer. Maybe you can order that too.
Thanks for all your coaching!! :D :D
