It is currently Wed Jan 24, 2018 3:48 am
PostPosted: Thu Feb 14, 2013 5:49 am
I met the owner of a 2013 Tandem Island today, and he told me that his TI has got black reinforcing tubes inserted in the central scupper holes. This is apparently a running change to TIs which I had not heard reported anywhere to date. So it looks like it is now OK to use a new TI using the new trolley insert.
Way to go Hobie!
PostPosted: Thu Feb 14, 2013 8:39 am
My 2012 TI has them as well.
PostPosted: Thu Feb 14, 2013 9:36 am
Hobie Tech / Moderator
You still can't use plug in carts on TI's - you need to at least use the cradle - or preferably the full dolly. Nothing has changed in our minds - the Plug In carts are not suitable for TI use.
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Thu Feb 14, 2013 9:44 am
Is the plug in cart not acceptable for a TI even with the little black stop collar on it? Because my dealer sure talked me into buying one with my TI back in September. I guess I'm glad that I haven't put it to much use this winter.
PostPosted: Thu Feb 14, 2013 9:55 am
Collar kit is not enough - you must add the cradle (part # 80044202) you risk damage from use of a plug in cart without the cradle.
Jacques Bernier
PostPosted: Thu Feb 14, 2013 11:46 am
Obvious questions:
Can the scupper tubes be added to existing AI/TI's?
Will the new cart cradle fit an AI hull as well?
PostPosted: Thu Feb 14, 2013 1:23 pm
NOHUHU wrote:
Obvious questions:
No - the tubes are only designed to fit in boats which have had their mold re-worked to adapt - the scuppers are over-sized and the inserts screw into the scupper - it is not backwards compatible...sorry.
The cradle might work okay with other models but wouldn't be a perfect fit, it's designed to fit the TI.
Jacques Bernier
PostPosted: Thu Feb 14, 2013 1:58 pm
Thanks- I thought so. I was going to install metal sleeves in my 08 hull, but it would have made it impossible to insert the scupper cart.
Without lube that is.
PostPosted: Thu Feb 14, 2013 2:10 pm
I think the first scupper tube reinforcement was by Josh (yakass). I think he used a broken Hobie paddle shaft. Here it is: http://modernkayakfishing.com/articles/264-scupper-hole-repair
PostPosted: Thu Feb 14, 2013 3:28 pm
Nohuhu,
Bob (fusioneng) posted how he reinforced his scuppers using PVC here:
viewtopic.php?f=69&t=35341
The new cart cradle will fit an AI but will only contact the hull in the middle section between the scupper tubes. The outer hull edges will not be supported but they aren't anyway when on the scupper cart so I guess using the cradle on an AI is better than not!
PostPosted: Thu Feb 14, 2013 4:19 pm
AI isn't such a problem due to how much it weighs... that's the main difference, the TI is heavy - and when left on the plug in carts it damages the hull severely - it must not be used without a cradle - or just go the dolly - AI is okay on a plug in cart - the issues are all related to TI.
Jacques Bernier
PostPosted: Thu Feb 14, 2013 5:05 pm
I saw that repair thread stringy. I doubt you can insert the cart after the mod though. It's tight.
Thanks for clarifying the AI fit w the new cradle. Cheers.
PostPosted: Fri Feb 15, 2013 1:47 am
Nohuhu,
Looks like I was wrong with the TI cradle fitting the AI hull. :oops:
I had thought that because the scupper carts fit all models that the central hull lobes would be the same but it turns out they're not. The groove between the lobes is further apart on the TI so the cradle doesn't fit well:
PostPosted: Fri Feb 15, 2013 2:34 am
OK - well, thanks for mucking that up then. ;-) Cheers!
Users browsing this forum: Google [Bot] and 1 guest
