It is currently Sun Mar 26, 2017 2:24 am
 Post subject: loose screw in hull
PostPosted: Thu Apr 11, 2013 4:05 am
Hi all. My name is Ryson. I'm a new 2013 AI owner and have been out with it once and loved it. Later that night when I was turning the hull upside down, I found a screw floating around inside. Its a fine thread machine screw with a round washer head that accepts an allen key. I'm not sure it was in the hull when I received it, but I didn't hear anything when I first unwrapped the hull. So far I've only had a few items actually inside the hull; c tug cart, a pair of bodyboarding fins, some rope, and a manual bilge pump. I've looked in and out of the hull and cannot find anything that resembles this screw nor can I find any holes that would take the screw, so I'm wondering if it even belongs on the AI. You guys probably know better since I've only had mine for a week. Thanks for your help!
Ryson
 Post subject: Re: loose screw in hull
PostPosted: Thu Apr 11, 2013 8:33 am
Hobie Tech / Moderator
This appears to be a rudder handle screw. I'm sure it was just dropped into the hull during assembly by mistake - that is the only spot that we use that particular screw - so nothing to worry about.
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Thu Apr 11, 2013 4:56 pm
awesome thanks!
