It is currently Sun Mar 26, 2017 7:55 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Bicycle Trailer
PostPosted: Sat May 11, 2013 9:06 pm
Have Tandem Island in Tampa Bay area, What a great sailing vessel!!! I live 4 blocks from launching site and I am thinking about a Trailex trailer=150lbs + TI @ 192lbs. Total weight = 342lbs. This is nothing to pull behind a car but I am thinking a Cargo Tricycle with an electric assist motor on it. I am looking into legalities about being on the street but I think I am legal. Is there anyone that can give me any advise pro or con. The tricycle is a 5 speed and with the electric assist motor is suppose to be able to haul 250lb cargo at 17 mph. Of course they are trying to sell me the trike and motor. Any comments would be appreciated.
Thanks,
Geege33708
Ps this is my first post.
Geege33708 Ferretjans
 Post subject: Re: Bicycle Trailer
PostPosted: Sat May 11, 2013 9:49 pm
What are the brakes like? :o :o :o
PostPosted: Sun May 12, 2013 1:06 am
How steep are the hills? :lol: Seriously, it sounds interesting, although I would tend to stay in a low gear and forget about 17mph.. To scary if it goes pear-shape!
PostPosted: Sun May 12, 2013 2:39 am
add the weight of the rider and the trike and you will be well over 550 pounds. it might work but don't expect much battery life. if you can get a gas assist motor then go for it.
the TI3 rear ama mod
PostPosted: Sun May 12, 2013 6:28 am
Probably need a 48v motor, and I would make sure you have disc brakes on that puppy, especially on front. If you can get metal brake pads, as opposed to the organ I ones that avid and shimano have now you will get better brake life.
I live in hilly Marin, and my cargo fully loaded with three passengers barely made it up my 22% grade road with me pedaling like crazy. Now with 48v battery and controller it is a breeze. I burn through brake pads at about twice the rate with the organics lasting a month or two in winter, and usually all summer. Metal pads last one full season
PostPosted: Sun May 12, 2013 12:18 pm
48 volt I can do. It's a hub type motor in front with a disk brake. Rear wheels will be coaster brakes. My biggest concern is stopping. No hills.
PostPosted: Mon May 13, 2013 5:38 am
Direct drive or geared motor? And is that 250# cargo, or total weight including rider?
If it is total weight, then it is probably pretty dicey- you'd be doubling the spec.
You probably want direct, as the geared have a minimum speed to get going, and that way you don't risk stripping the gears.
Stopping you probably need some distance, but with a DD you'll get resistance, worst case you will have to replace the front pads a lot.
The only thing I would worry about is the front head tube and fork, but if the trike is rated for that weight in cargo, you should e OK there, or at least you aren't totally blowing the weight limits out of the water.
PostPosted: Mon May 13, 2013 8:14 am
250# is the weight that can be carried on the trike load platform. The weight of the trailer tongue would be a mere fraction of that. The weight of the boat will have little effect on the load the trike can carry, it's the load that it is pulling is the question. (and stopping) I am sure there is some kind of formula for figuring this out. Remember the commercial were the Toyota pulled the space shuttle from the airport to the museum. It's all about pulling power. And what about the guy who pulls the semi truck with his teeth. I guess the only way to find out is to just do it! (Swoosh)
PostPosted: Mon May 13, 2013 8:27 am
I have a TI on the early Trailex 200 trailer (Hobie now uses a more robust trailer for TI, and for car pulling, that's a good idea). The trailer is easy enough to pull around that I think I could do it for several miles on the flat, on good pavement, with my bike and no assist (pant, pant). But I would be in a low gear, and going fairly slowly. My question on the motor would be whether it worked well at low bike speeds, since these hub motors have no gearing. If there were any kind of hills, let alone Marin's 22 grades, I really doubt this would work out. But Florida is about as flat as it gets. I think it will work, and you will get some valuable workout helping out your motor. I think it would be better with some kind of custom trailer using larger diameter, bike type wheels, but you can get the Trailex stock, a big plus.
PostPosted: Mon May 13, 2013 8:30 am
I would imagine the legality could hinge on not having brake lights and turn signals functioning on a trailer that has them.
PostPosted: Mon May 13, 2013 3:04 pm
The low speed is key-- that's why you need a direct drive, not a geared motor. Direct drive will engage at almost any speed, while the geared motors require a min prior to kicking in.
i have to walk my bike up (when loaded) some of the hills, and the direct drive will help even when starting from a dead stop. My old geared motor wouldn't do that
PostPosted: Sat May 25, 2013 8:41 am
I have just seen and touched a Trailex trailer with a TI on it and believe it will be easily towed by a Tricycle especially a motor assisted. My next step is a Trailex trailer. Anyone have one for sale in the Tampa St Pete area?
PostPosted: Sat May 25, 2013 9:08 am
The question should be do you think you can stop it in a reasonable distance and length of time??
PostPosted: Sat May 25, 2013 2:11 pm
He could always invest in those flip flops that have recycled car tire threads on the bottom to use for brakes. :D
PostPosted: Wed May 29, 2013 12:06 pm
I am also interested in taking the TI behind an electric bike, but I don't want any trailer. Just put wheels on/under the TI. When you come to the water you can put the bike on the TI!
The main problem is that you also need to have breaks on it. I haven't started to think about that problem, but I am thankful for suggestions.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
