It is currently Thu Jun 04, 2020 4:16 pm
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Mon Aug 13, 2018 2:25 pm
Just a short shoutout and big thanks to Hobie and my excellent Swedish dealer Kayakstore.
After some waiting (out of stock) the free upgrade (Aka clips and Furler guide) arrived and is mounted succesfully. As my craft still is pretty new I had no problems with seized corroded screws on the knuckles but I can see a problem in the future. I put some aluminium paste/grease on the screws if I need to remove them again in the future.
Thanks for the free gear and good support.
/Gustav
Sailing my TI and fishing.... thats bliss!!
PostPosted: Thu Aug 29, 2019 1:01 pm
Finally got dealer to order upgrades, thanks to this thread. Cant wait for that furler add.
PostPosted: Tue Sep 24, 2019 3:19 am
Quick note to anyone else considering upgrading their aka clips:
We lost an aka whilst sailing at sea off Falmouth (UK) last summer - no warning, front (windward) aka bar just came out & wife ended up in the water, clinging on to a tangle of tramp, bars & the ama. Quickly furled the sail & awkwardly paddled to nearest beach with her in the water holding onto the parts as best she could. No big drama in the end but could have been much worse if it had been the leeward aka that came out, or we had been much further out from a landing spot!
In the moment, I presumed something had broken, but once at shore found the aka had simply slipped from it's clips - it clicked back in but I could see how easily with just the slightest of touch of a button it comes out - so I presume just the movement & twisting through the waves had released it.
Anyway, I was aware of the upgraded clips thanks to this site, ordered the upgrades but didn't get around to fitting over the winter so ended up having to take them on hols with us this summer, and this is how I fitted them with just basic tools & WD40:
Soaked the screw heads with WD40 & checked I could loosen each one before proceeding. Lucky for me they all came free (2017 model regularly hosed with fresh water) - after reading others experiences on here, that was the most worrying part for me!
Then with a good squirt of WD40 up the tube, I could depress the clip buttons & lever the clips slightly outward using a flathead screwdriver.
Without any long-nosed pliers (or metal coat-hangers to bend), I cut a 3 foot length of cord, threaded each end through the same button hole, poking one end above & one below the clip, pushed it through until both ends came out the tube. Wrap the cord around the hand & with a few sharp tugs the clips came flying out.
I used a broom handle to push the replacement clips back up the tube - with some care it's easy to push until the buttons line up with the holes and they simply pop into place. Replace screws - job done.
I could see no difference in the replacement aka bar ends, even though the illustration appears to show an increased ramp angle, but replaced them anyway - if you are suffering from corroded screws you could save yourself the hassle here.
It feels considerably more positive & secure mechanism now, so due to our experience I consider this an essential upgrade, and in the meantime I would recommend taking other precautions mentioned on here such as securing-lines between each knuckle.
Hope this is of some help, and offers encouragement to those still thinking about it! :)
PostPosted: Tue Sep 24, 2019 5:01 am
As I have posted in the past, there have been many examples given on how to "harden" your Island, and ensuring the akas cannot possibly become attached in error is one of them. Cost is a few bucks only...
Buy some dyneema line (Hobie rudder line)
Tie a tight loop around the top of the aka hinge
Tie inner end to the deadeye in the middle of the hull, using a small carabiner if you want to be able to detach the aka from th hull (I have detached mine once since 2012!)
Repeat for each aka.
That's it! You will need to undo the line if you need to detach the aka, as the line will physically prevent the aka moving outwards, even if the Hobie fitting fails, but YOU get to choose when that happens!
PostPosted: Tue Sep 24, 2019 6:47 am
Like Tony said, there are plenty of simple mods posted that address a lot of issues.
I just added a loop of heavy duty bungee cord that slips under front & rear crossbars & attached bungee button to each aka bar just past the knuckle. After inserting & locking aka bars into crossbar, simply just pull bungee over & secure onto button on aka bar. It makes a quick & very secure backup so aka bar will not pull out.
Bob
Proud member Kayak Fishing Association of New York
PostPosted: Thu Jan 23, 2020 12:56 pm
Hi Matt,
I just bought a used 2015 TI and it doesn't have either of these updates (i.e., the aka lock update and furler line guide). Can I still get these parts? The closest dealer to me is TackleShack (https://shop.tackleshack.com/) in Pinellas Park, FL.
Thank you!
2015 Hobie Tandem Island
Ivory Dune
Trampolines, Spinnaker Kit, Lowrance Hook4, Vantage Seat Accessory Bag, GoPro Hero3+, RTIC SoftPak 30
PostPosted: Thu Jan 23, 2020 1:42 pm
Yes, ask the dealer to file a claim.
