It is currently Sun Mar 24, 2019 7:31 pm
 Post subject: Davis Spar Fly
PostPosted: Mon Aug 27, 2018 10:03 am
I'm interested in adding the Davis Spar Fly to my TI mast. Has anyone successfully mounted one ? Is there enough space at the top of the mast (above the sail) to mount the quick release mount ? Is it OK to drill the small mounting holes into the mast without compromising the carbon fiber ?
thanx,
bill
 Post subject: Re: Davis Spar Fly
PostPosted: Mon Aug 27, 2018 2:39 pm
thanx,
bill
I don't have that particular item, but my wind indicator has a similar mounting requirement. If you have the Hobie spinnaker kit, simply remove the base and zip-tie the vertical rod to the little stubby rod on the mast-rotator.
If you don't, you can easily attach a small piece of pvc plumbing pipe with a single screw over the top of the sail, and add in a small plastic tube into which you can insert the rod of the Spar. The photo says it best.
2012 Tandem Island "SIC EM" with Hobie spinnaker and Hangkai outboard
only cool people follow the (non-magnetic) titanium weight-loss program! lol.)
Users browsing this forum: Majestic-12 [Bot] and 1 guest
