It is currently Tue Feb 25, 2020 8:46 am
PostPosted: Mon Aug 26, 2019 7:18 pm
I have an Adventure Island that is pre-2011 (I think it is 2008) and need to buy replacement rudder pins.
Hobie lists part 81394001 for pre-2011 AIs and this looks identical to the one that snapped.
My problem is that my local sources (in Canada) are out of stock for that part.
I'm wondering if part 81394021 which is described as RUDDER PIN 2011 CENTERLINE
STYLE REQUIRES MODIFIED HOUSING will work.
So, is the post 2011 AI rudder pin compatible with pre 2011 AIs?
Thanks.
PostPosted: Wed Aug 28, 2019 6:00 pm
Any pre 2015 AI pins should work fine. The only difference the center-line pin should be is a groove that the up/down lines rest in.
http://KayakingBob.com - - - - - - - - - - Hobie Island Sailing since 2006 - - - - - - - - - - SpraySkirts
