Island hatch material and can it be glued? http://www.hobie.com/forums/viewtopic.php?f=71&t=70706 |
Author: | siravingmon [ Tue Apr 25, 2023 8:36 pm ] |
Post subject: | Island hatch material and can it be glued? |
Hi, Does anyone know what material the island hatch covers are made of, and whether any glue works with that material please? Thanks in anticipation! |
Author: | dutchman [ Tue Apr 25, 2023 11:53 pm ] |
Post subject: | Re: Island hatch material and can it be glued? |
Rotomolted plastic As far as i know you can’t glue it, but you can weld it with a soldering iron Iff you weld it at the underside of the hatch you wil hardly see it at the topside Is this the answer you needed? Peter |
Author: | dutchman [ Wed Apr 26, 2023 12:12 am ] |
P.S. I am talking about the front hatch in the bow The 8” hatches i don’t know or glue will stick on them, they are made from a diferend type of plastic |
Author: | siravingmon [ Wed Apr 26, 2023 12:19 am ] |
Thanks! I should have been clearer - I meant the 8” hatch cover at the rear |
Author: | pro10is [ Wed Apr 26, 2023 3:26 am ] |
siravingmon wrote: Thanks! I should have been clearer - I meant the 8” hatch cover at the rear Gluing plastic is difficult and undependable. All parts of the rear hatch are available as replacement parts. That would be a much better solution. |
Author: | siravingmon [ Wed Apr 26, 2023 3:34 am ] |
Thanks but it’s not broeken - I want to mount a tiller pivot on it |
Author: | pro10is [ Wed Apr 26, 2023 4:50 am ] |
siravingmon wrote: Thanks but it’s not broeken - I want to mount a tiller pivot on it Glue would not work well for that if at all. It would be best to use a bracket screwed to the cover. |
Author: | siravingmon [ Wed Apr 26, 2023 7:13 am ] |
Thanks for that! |
