Are the Xbar holes for a 2009 AI the same spacing http://www.hobie.com/forums/viewtopic.php?f=71&t=71048 |
Author: | SEAROBIN [ Sat Aug 26, 2023 12:09 pm ] |
Post subject: | Are the Xbar holes for a 2009 AI the same spacing |
I have a 2009 AI that developed a crack under the click-n-go. I’m going to try to weld it then cover with G-flex. If that doesn’t work an out of state friend has a slightly newer AI hull ( with the orca fin rudder & the aka’s that are tube like and slide into each other instead of the pins mine has). If I unbolt my Xbar, is the spacing the same to put my bars on his hull? Thank you. |
Author: | SEAROBIN [ Thu Aug 31, 2023 6:17 pm ] |
Post subject: | Re: Are the Xbar holes for a 2009 AI the same spacing |
Let me try wording it differently. Can the sailing parts of a 2009 AI be bolted on to a later year AI hull or are the bolts spaced differently? Thank you. |
