It is currently Sun Jan 21, 2018 7:03 pm
PostPosted: Fri Mar 28, 2008 1:17 pm
I was wondering - For safety reasons - In case one of the lines attached to the rudder get loose - and the rudder does not operate - what would you do ? use the paddle as a "rudder"? any ideas what to do in such unfortunate event ??
PostPosted: Fri Mar 28, 2008 1:20 pm
The paddle can be used in a pinch.
PostPosted: Fri Mar 28, 2008 7:40 pm
Hobie Team Member
First.
Get it up and locked down. Even if you have to go into the water to do so.
As Cheika states you can then use your paddle- to steer while pedaling/sailing.
Or if your paddling, different types of paddling strokes to steer the yak..
Aloha
Dan
PostPosted: Fri Apr 04, 2008 7:31 am
I snapped a rudder pin once in 20 knot winds and was able to sail the yak back 2 miles, using the paddle as a rudder. So it will work. I actually keep my paddle broken down in the front hatch and just grabbed half the paddle and used that. Reefed the sail and sailed home.
NorskBoy
