It is currently Mon Dec 18, 2017 1:55 am
PostPosted: Thu Dec 25, 2008 11:56 am
Is it alright to store the AI on the nose in a covered protected area? Would the weight on the nose distort the kayak at all? I was thinking of using a large pad under the nose to protect it.
I have two options, storing it on the top rack (8 ft high) of a metal storage system (kayak cubby holes) in one of those public storage places or storing it on the nose in a cage at a different public storage place. It is going to be a pain in the arse to get the AI up on top of the 8 ft high cubby holes, so that's why I was trying to check into storing it on the nose....
J
PostPosted: Fri Dec 26, 2008 11:49 pm
I'm really not sure, but would probably not want to do that to mine. You could make up a simple frame that takes the weight onto the front cross bar. Should be a better distribution of stresses.
Geoff.
PostPosted: Sat Dec 27, 2008 1:05 am
Standing nose down on end is one of the Hobie recommended storage solutions. Others are hull up or on side. Check the FAQ here:
http://www.hobiecat.com/community/viewtopic.php?t=1152
PostPosted: Sun Dec 28, 2008 9:54 pm
Standing upright is one of the recommended storage solutions on the Hobie Kayak DVD that came with the AI.
Mickey
PostPosted: Mon Dec 29, 2008 12:29 am
If you go on a factory tour you'll see that Hobie stores theirs straight up. 8)
PostPosted: Mon Dec 29, 2008 7:23 am
As for a pad on the nose when storing it on end, you might try the inexpensive foam knee pads from Home Depot.
The knee pad also works great by putting it on the end of your boat that is on the ground when loading it on the roof of a vehicle. The strap holds it in place.
Everything before 60 is just a rehearsal!
