It is currently Thu Dec 14, 2017 6:30 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: AI Cradle Spacing
PostPosted: Thu Feb 09, 2012 6:32 pm
Quick check - I get around 104"
The TI's are 13' 4".
The link shows a TI assembled up there with Aks, which would be a complete waste of time.
If you go with cradles for the AI, I'm guessing you'll end up strapping the hull and Amas individually. Maybe using shorter tiedown straps.
Here's a good approach:
http://www.hobiecat.com/forums/viewtopic.php?f=73&t=36089
PostPosted: Fri Feb 10, 2012 10:17 am
NOHUHU wrote:
Nohuhu, thanks for Link to Bob's site. Very useful.
Your suggestion above is almost exactly the approach I am planning, akas attached to hull and in the craddle for the ride. I couldn't do your suggested approach with tonneau cover on bed. Mow that I have dimentions, I'll figure something out. Thanks.
PostPosted: Fri Feb 10, 2012 12:42 pm
I'm sure you'll find a righteous solution. When you do, please post photos.
PostPosted: Fri Jun 08, 2012 11:14 pm
I guess this is more efficient rather than having a trailer at the back. It would likely ease up driving. But regarding the tonneau cover does it take fabrication or modification on the bed to make it work properly?
"Love it or hate it"
autoparts warehouse
PostPosted: Thu Jun 05, 2014 10:09 pm
mmiller wrote:
The AI set is form fitted to a specific spot on the hull, so 67". (edit!)
The TI version could work I think. It would not be as snug.
I too think dis assembly is a better option for car topping though. Much easier to handle the separate parts when loading up top.
is the dimension of 67" measured mounting hole centre of one cradle to the mounting hole centre of the other cradle? Or is it inside edge to inside edge?
PostPosted: Fri Jun 06, 2014 3:17 pm
Mine is measured centre hole to centre hole.
PostPosted: Sun Jun 08, 2014 6:16 am
Thanks John. That's what I thought it would be.
Users browsing this forum: Yahoo [Bot] and 1 guest
