Trailex Leaf Spring: Jammed? http://www.hobie.com/forums/viewtopic.php?f=73&t=60270 |
Author: | PeteCress [ Mon Apr 10, 2017 11:27 am ] |
Post subject: | Trailex Leaf Spring: Jammed? |
Pulled into the driveway this evening and found that the right-hand leaf spring was fully-compressed (note that the link is horizontal instead of vertical): https://photos.google.com/share/AF1QipM ... FRQThPRVJ3 https://photos.google.com/share/AF1QipP ... JaRW5TYzBR I had marked the positions of the front/rear spring attachments and they had not changed. (first time out, the fore attachments slid forward, flattening both springs... but then I put an additional stop-nut in front of each and that has not recurred) Figured it must be one of the bolts binding, so I turned the trailer over, loosened every bolt associated with the spring, but it did not snap back. OTOH, I put a screw driver under the rear of the link, pried it up a few degrees, and it snapped back. https://photos.google.com/share/AF1QipP ... JaRW5TYzBR Note that the link is not precisely horizontal - more like a few degrees past horizontal. Does anybody have thoughts on this? |
Author: | mmiller [ Mon Apr 10, 2017 12:05 pm ] |
Post subject: | Re: Trailex Leaf Spring: Jammed? |
Give Trailex a call... Phone: 800-282-5042 Local: 330-533-6814 Email: [email protected] |
Author: | cooldudecaptain [ Mon Apr 10, 2017 7:17 pm ] |
Ken Montgomery (ext 204) is a wealth of knowledge at Trailex. It's the spring shackle that rotated. |
