It is currently Thu Jun 22, 2017 8:10 am
 Post subject: Newbie questions
PostPosted: Sun Apr 17, 2011 3:14 pm
Hi everyone,
We are the proud owners of used but new to us a 2008 AI and a 2011 AI. I have a couple questions.
First on the dagger board for the 2011 I do not have the same eye hook (if that is what it is called) to hook the cord too like as the 2008 model. Where do you attach that too, I know the dagger board is different on the 2011 model. Is mine 2011 missing the eye hook?
Second On the cart, I have the hd hobie cart with the cart keeper, if I am understanding correctly the plastic bushings are all the way down to the hobie pad on the crossbar. The hull is just about touching. This leaves the the cart keeper pin like 6" up into the kayak, is this correct. Or should I have the bushings adjusted up so the keeper in has a tighter kit?
Thanks for you help
Rob
 Post subject: Re: Newbie questions
PostPosted: Mon Apr 18, 2011 10:48 am
Congratulations, and welcome!
Could you post a picture of the daggerboard without a hole?
On the cart, you want the bushings low enough, so crossbar just touches the hul in the center. Better yet, put it all the way down, and add a tennis ball to ceac side to cushion the hull scuppers. (a Roadrunner tip) The reason the cart is so long is the TI has a much thicker hull, and the carts are made for both (all) boats.
PostPosted: Mon Apr 18, 2011 3:52 pm
Rob,
I take it you mean the bungee eyelet attachment point under the seat strap as seen here?
I have a new '11 hull and wondered the same thing as it's not there on mine either. :roll:
After routing the DB bungee through the padeye I stretched it up to the paddle holder cleat. I'll have to get some longer bungee though as there was no stretch left in it once hooked to the cleat.
What are Hobie suggesting for securing the DB bungee to on '11 models?
PostPosted: Mon Apr 18, 2011 4:37 pm
Thanks for the replys
Stringy, that is the exact same thing I am doing with the paddle holder cleat, that just does not seem the correct way. Your picture is the same as my 2008 AI, but not the 2011. I also wonder what Hobie suggest for this?
Reconlon, thanks for the tennis ball tip. So the cart keeper pin really does not do much at the higher height? Would it be better to put another pin lower?
Rob
PostPosted: Mon Apr 18, 2011 7:18 pm
The pin just stops the cart from falling off when you lift up your boat.
PostPosted: Tue Apr 19, 2011 5:59 pm
Thanks again Reconlon
Does anyone know the correct way to hook up the dagger board on the 2011 models. Our we supposed to use the paddle holder cleat or not. Maybe someone from hobie can chimne in.
PS. my springer spainel is loving the tramps :)
PostPosted: Wed Apr 20, 2011 10:32 am
According to our engineers the bungee system has not changed, so I checked with the assembly line. We determined that the mold was changed for the new side handles and the eyelet was left off in error. Assembly didn't question it because the hardware locations were changed and no location for the eyelet was provided. We will be contacting dealers shortly about this, so hang tight.
This is still correct:
You will need to see a dealer for the needed parts and or installation at no charge.
If you want to locate parts before we get this to dealers, the parts required are:
Eyelet post 41220001
Screw 10-32 x 1" 8030251
Nut 10-32 STANDARD NYLOC 8050201
Requires a 3/16" drill.
The proper location is:
PostPosted: Wed Apr 20, 2011 4:38 pm
Thanks Matt,
I bought mine used even thou it is a 2011, would the local dealer assist with this even that I did not buy it there. It is a easy repair and I do not mind doing it myself. I just need the parts.
Rob
PostPosted: Thu Apr 21, 2011 9:11 am
No problem second owner or first. Dealers will learn of this today.
PostPosted: Thu Apr 21, 2011 3:01 pm
Matt,
Thanks for getting this sorted. 8)
What amazes me is that it sounds like it was this post that alerted Hobie to the problem. :shock:
How long have the '11's been available? Don't dealers provide feedback? Makes me wonder how thoroughly changes are tested? :?
The new handles are great but I noticed on my first trip in the new hull how they funnel water straight into the seatwell. :(
There are many improvements in the '11 hull. The larger rudder is amazingly responsive and is not overpowered by the sail, the new rudder handle and improved line routing make for smoother steering, the hull finish is noticeably improved and I had a very dry internal hull after a quite choppy trip.
It's a shame that with all these forward steps a couple of backward steps have been taken that could have been avoided by better testing before product release. :roll:
PostPosted: Thu Apr 21, 2011 3:27 pm
Amazing! I hadn't even noticed this :o :roll:
Mickey
2011 AI Golden Papaya
PostPosted: Thu Apr 21, 2011 5:12 pm
That's because you hardly ever use your daggerboard! :o :shock: :lol:
PostPosted: Thu Apr 21, 2011 5:17 pm
Yep... this thread is how I learned of it. People were simply hooking to the paddle cleat and figured that was that. Everyone from assembly to dealers and then users simply never noticed.
The handles were well tested on the Tandem Island since last year, but that boat is a little higher... same issue though. We are looking at foam plugs or flaps to divert water and not block the intend use. They are nice for holding while pedaling too.
PostPosted: Thu Apr 21, 2011 7:20 pm
Agreed Matt. :)
They are a real benefit also when sailing in kayak mode with the small sail! I used to grab the molded indentations to 'hike out' but the handles are a huge improvement, offering a very positive grip.
PS: Might I suggest that in future, Roadrunner (if he is agreeable), be put on the payroll to give any improvements the thumbs up. These issues would never have gotten past his beady eyes! :wink:
PostPosted: Thu Apr 21, 2011 9:17 pm
Thanks for that excellent suggestion stringy! I would be thoroughly delighted to test any and all of Hobie's toys at no charge. The only downside to getting paid might be the loss of capacity to render an independent opinion or review on the forum. One shouldn't compromise one's principles in such matters ... for less than 3 or 4 dollars or a free lunch at the very least! :D
Image Having been trained by Mr. Magoo himself, all could rest easy knowing that nothing would get past these beady eyes! :mrgreen:
