It is currently Tue Jan 16, 2018 5:20 am
PostPosted: Mon May 16, 2011 12:15 am
As it says in the title, the mast can be pulled out.
I've adjusted it as in a previous post but still .....
Nowt in the bottom by the way.
PostPosted: Mon May 16, 2011 8:10 am
Is the furler drum / collar slipping up the mast?
PostPosted: Mon May 16, 2011 9:04 am
As you are probably aware, there is a small hole in the bottom of the mast holder that the pin on the bottom of the mast fits into. If some debris got into the hole it can prevent the mast from fully seating. On our Everglades trips it tends to be sand. Check it out.
Also, if there is debris in the hole and you do manage to push the mast hard enough to snap in place the added pressure on the mast lock may cause it to be REALLY difficult to get it to unlock later.
PostPosted: Mon May 16, 2011 11:45 am
Only early models have a female connection in the receiver... newer models are male with the female in the mast base.
PostPosted: Tue May 17, 2011 12:14 am
theres nothing in the reciever, as for the drum i dont think so, probably just needs adjusting better.
just which way? trial and error???
PostPosted: Tue May 17, 2011 9:13 am
What year model?
Only older crossbar versions (not V2) can be adjusted. V2 crossbar bolts to the receiver and stays constant.
If not locking in, the mast is not getting far enough down, so place the mast in the receiver... adjust the "V" brace to force the receiver lower until the stainless tab locks the mast in.
PostPosted: Tue May 17, 2011 11:36 pm
2010 model,
I'll have a look at the weekend
PostPosted: Wed May 18, 2011 9:37 am
V2 only started on AIs for 2011, to you should be able to adjust this one with the "V" brace.
