It is currently Tue Jun 27, 2017 10:56 pm
 Post subject: Suddenly loose steering
PostPosted: Mon Jun 20, 2011 8:45 am
I was taking my brand new TI out for some testing in a small harbor and all of a sudden the steering handles (both of them) developed about an inch of slop in control. Steering still works lock to lock, but were there was once a nice tight feel in the steering handle and probably a 60 degree control arc, now I can swing the handle almost 180 degrees.
Anyone have any ideas what happened?
Btw, The boat wasn't even rigged up, just kayaking with the mirage drive.
PostPosted: Mon Jun 20, 2011 9:18 am
I suspect a slipped knot or possibly something was hung up upon the initial rigging of the system. You can adjust out the slack at the rudder.
PostPosted: Mon Jun 20, 2011 10:59 am
First two times out with the new rudder my stearing got very sloppy. The third time I tightened it I realized there is a nut under the rudder that the stearing adjustment screws go through and mine was turning. I put a wrench on them when tightening and my problem appears to be solved.
I double checked the video and they don't mention the nuts.
Jerry D.
St. Johns, Florida
2010 TI
2008 AI
PostPosted: Mon Jun 20, 2011 2:06 pm
The nut should be in a hex recess, so pliers would not be necessary. Your's spinning in the recess?
