It is currently Sun Jan 21, 2018 12:21 am
 Post subject: Is this normal?
PostPosted: Mon Aug 06, 2012 8:16 pm
I Just picked up my TI tonight and I noticed that the rear seat scuppers are not actually solid and don't necessarily line up with the tubes going down to below. It seems that this could lead to a problem with water not leaving the well, but rather entering the hull itself.
 Post subject: Re: Is this normal?
PostPosted: Mon Aug 06, 2012 9:00 pm
Should be fine. Those are protective sleeves that help prevent scupper cart damage. The old boats didn't have them. You're actually less at risk of a problem with your newer boat.
I'm assuming that there is not a hole above the black part, but just a gap, if that's the case I wouldn't worry about things not lining up perfectly. That's pretty close, and from what I understand, the rotomolding process isn't an exact science. If it made it to the dealer, and to you, it's probably passed inspection, and is fine.
If that were my boat, I wouldn't have a worry at all.
PostPosted: Mon Aug 06, 2012 9:46 pm
Can you reduce the size of the photo by about a factor of four so it can been seen on a single screen?
BTW, don't worry about the black bit, as augang said
2012 Tandem Island "SIC EM" with Hobie spinnaker and Hangkai outboard
only cool people follow the (non-magnetic) titanium weight-loss program! lol.)
