It is currently Mon Mar 18, 2019 5:33 pm
PostPosted: Wed Sep 28, 2016 7:51 pm
I bought the rudder control line kit. Has 4 lines and 4 plastic tubes.
Two of the lines are longer than the other two.
I am assuming the longer lines are replacements for the steering lines. Shorter lines replacements for up/down rudder control.
I was told the steering lines go through the left and right holes in the back of the hull and through the tubes (obviously).
Does the other end go all the way back to the rear tiller control under the hull? How is it attached? Can't see where the end of the line attaches to the tiller as it is inside the boat.
Anyone got a photo?
I'd rather have a bottle in front of me, than a frontal lobotomy!
PostPosted: Thu Sep 29, 2016 10:23 am
There is a repair manual that should help. There are different versions depending on your rudder and controls vintage:
http://www.hobiecat.com/support/
Choose your boat model...
This one is for the twist and stow and up / down line systems:
http://static.hobiecat.com/digital_assets/Twist-n-Stow_Repair_Manual.pdf
PostPosted: Thu Sep 29, 2016 2:53 pm
Thanks. Unfortunately, I have a pre 2015 TI. Manual doesn't have anything on replacing steering lines. The manual for the new TI goes into depth about changing lines, but the new TI is quite different.
I'll get a mirror so I can get a better look down below.
PostPosted: Thu Sep 29, 2016 5:09 pm
Use a cell phone and video? or stills?
PostPosted: Thu Sep 29, 2016 8:59 pm
I am unaware of any changes to the lines on a TI. Can you please advise what is different (Matt? Any input?)
2012 Tandem Island "SIC EM" with Hobie spinnaker and Hangkai outboard
only cool people follow the (non-magnetic) titanium weight-loss program! lol.)
PostPosted: Fri Sep 30, 2016 9:56 am
I'm not aware of any major changes within the kayak.
PostPosted: Fri Sep 30, 2016 3:56 pm
I was comparing this photo of the 2015
http://static.hobiecat.com/2010_archive ... 5_opt.jpeg
With this
http://i1094.photobucket.com/albums/i45 ... 12_649.jpg
Maybe not the same? Apples and oranges?
OTOH, I watched a hobie video on rudder replacement, and the guy didn't go all the way back to the tiller. He just cut the steering lines at the rudder, removed the ends attached to the rudder head, fed the new lines from the rudder head to the rear hatch, where he tied them to the cut end leading back to the tiller.
https://youtu.be/lHoTj92jOcY
