It is currently Tue Nov 12, 2019 6:26 am
PostPosted: Tue May 08, 2018 10:12 am
It would be appreciated, thanks.
I'm also curious why the PA has an in-line BOA for the rudder system, but the Island series doesn't?
Last edited by Pescatoral Pursuit on Fri May 11, 2018 12:25 pm, edited 1 time in total.
PostPosted: Tue May 08, 2018 11:56 am
When I got my 2015 AI 2 and my new 2014 TI, I pulled the foam blocks out and discarded them. I need that space on camping trips.
PostPosted: Tue May 08, 2018 2:15 pm
To each his own. I do a lot of standing in my kayak and will be taking it in the ocean in pursuit of toothy critters. Support and emergency flotation are premium. Already have enough in-hull stowage.
Now about that diagram...
PostPosted: Tue May 08, 2018 2:43 pm
You do have to be careful with any foam blocks you add to the interior, that they do NOT get tangled up in the rudder lines.
PostPosted: Wed May 09, 2018 5:43 am
Yes. This is why I'm asking the manufacturer for the layout.
PostPosted: Fri May 11, 2018 12:24 pm
Bump.
PostPosted: Fri May 11, 2018 12:39 pm
I don't have a diagram unfortunately. I'll ask Jacques to respond if he knows. These are primarily for safety flotation, so may vary in location for most models.
The boa is not strong enough for the rudder loads in the Islands.
PostPosted: Fri May 11, 2018 1:03 pm
Hobie Tech / Moderator
They are not placed in the hulls for support as we do in models for standing (like PA's or Outback) They just stuff inside the hull where they can fit. Yes - sometimes there's interference with steering, it's something that the assembly guys know to be aware of, but they can also shift around in shipping, during use or trailering.
Boa isn't suitable due to the hi loads of the steering system (I think Matt replied with the same answer)
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Fri May 11, 2018 9:57 pm
I stand and fish and will likely straddle the mirage well where it's flat. Do you recommend this area be supported underneath?
Thanks.
PostPosted: Sat May 12, 2018 8:08 am
Check out the thread "SPEED" where foam pillars (pool noodles) are used to support the hull. https://www.hobie.com/forums/viewtopic. ... 04#p296962
