It is currently Sat Jan 18, 2020 4:32 am
PostPosted: Sat Jun 15, 2019 7:24 am
When the bungee failed to hold the drive blades against the hull, the fins dug into the sand and broke off the plastic alignment pins. This appears to render the entire drive useless.
Any suggestions on how to repair?
The design is is flawed. The alignment pins should not be solid molded, put replaceable, like the rudder pin.
PostPosted: Sat Jun 15, 2019 1:15 pm
The Alignment pins are removable on my Mirage Drives. Maybe it's the year (2015) or maybe it's just not obvious?
http://KayakingBob.com - - - - - - - - - - Hobie Island Sailing since 2006 - - - - - - - - - - SpraySkirts
PostPosted: Mon Jun 17, 2019 9:07 am
Here's the picture.
[url]
https://photos.app.goo.gl/R7ezV9JHu2Eutzqk8[/url]
PostPosted: Mon Jun 17, 2019 9:44 am
Different than mine. The alignment pins were only for making it easier to insert the drive correctly unless that has changed too...
PostPosted: Mon Jun 17, 2019 12:53 pm
If it were me I would drill it out and put in a stainless panhead screw and then build it up around the screw with Plast-aid. That stuff is amazing and is easy to work with and mold with your hands to match original size. It cures very strong and hard as a rock and with the screw as a base it will probably stronger than factory original.
Here is a link to it on Amazon. I cant tell you how many things I have repaired with this that would have otherwise needed to be tossed because no other epoxy or glue would have worked!
https://www.amazon.com/Plast-aid-Multip ... way&sr=8-3
PostPosted: Tue Jun 18, 2019 1:06 pm
The pins only assist someone who does not understand how the drive rests in the well. Completely unnecessary to the drive function.
PostPosted: Tue Jun 18, 2019 10:27 pm
Pins are not necessary for function of the drive, older models dont even have them, just an aid to insertion. Drives do rock back and forth due to tolarances, but when under load will be held firmly on front drive ledge.
PostPosted: Tue Jun 25, 2019 3:27 pm
Matt: Your response is not completely accurate (and a bit rude). The plastic nubs below the metal locking pins are needed to prevent the pedals from rocking. Is there a known repair to replace the plastic nubs?
PostPosted: Tue Jun 25, 2019 7:53 pm
If the pin does not exist on earlier model Miragedrives, and the rest of the design is basically unchanged, quite clearly the "extra" pin is NOT vital, so I believe you are being unfair to Matt's response. The drive relies on four contact points, axle (2) and front and rear points which rest on the lips of the drive well.
PostPosted: Tue Jun 25, 2019 10:11 pm
I hacked the pins off the drives that came with my Oasis to use on my older Outfitter kayaks. Now they work fine in both and there is no extra “rocking” in either.
Peter
PostPosted: Wed Jun 26, 2019 12:33 pm
Correct... Not "necessary". They have no function, but to assist in drive installation. They are not meant to limit rocking. If they did absorb some load when pedaling they would snap. We have seen where drives are not fully lowered in the well and all the load goes to these pins... which would also cause them to fail.
PostPosted: Wed Jun 26, 2019 7:44 pm
It's obvious brettboston knows way more about hobie engineering than the hobie people.
PostPosted: Wed Jun 26, 2019 8:25 pm
Yep. I am reminded of the old saying (paraphrased): "It is sometimes better to sit in silence while others question your intelligence, than to open your mouth and remove all doubt."
PostPosted: Thu Jun 27, 2019 9:08 am
To the question:
Unfortunately, no. The reason they are now molded in the spine has to do with the structure added that created a fairing to reduce water flow up into the well. We have made some changes to the mold to beef them up a bit.
PostPosted: Thu Jun 27, 2019 10:40 am
Matt: Thanks for your patience. There was a piece of debris stuck in the bottom of the hull slot that prevented the pedal drives from inserting. That was - and not the loss of the plastic nubs, as you knew - the reason for the reason for the rocking. This crow sure tastes good... not.
