It is currently Sat Mar 28, 2020 1:06 pm
 Post subject: Modified drive cable?
PostPosted: Sat Apr 07, 2007 12:15 pm
Didn’t see this posted on this site, so here it is:
"Pelican new prototype
Monday, April 02, 2007, 9:37:00 AM
With the abuse I was subjecting the drives to, I found over time, I was breaking the steel cable portion of the chains. The engineers at Hobie determined it was only a problem when logging miles in the 4 digit range, but made a very subtle modification using a more rounded piece that the cable bends around before attaching to the drive. It eliminates a slight twist when the pedals are fully extended. It has proven to be a good fix since there was no observable wear that I could detect. It's gone back to the factory for closer inspection, but I see no need to carry extra chains on the long hauls. Everything else seems the same so there's no difference in performance."
http://www.watertribe.com/Default.aspx? ... mReplies=8
