It is currently Thu May 13, 2021 3:26 am
 Post subject: Breach in the HULL!!
PostPosted: Sun Feb 28, 2021 4:56 am
:o we had a hole under the mast receptacle... watch video to see our repair. Feel free to share!
https://youtu.be/gQywIuVwhXk
 Post subject: Re: Breach in the HULL!!
PostPosted: Mon Mar 01, 2021 4:53 am
It's very difficult to affect a successful large-sized hull breach repair on a polyethylene hull because of its very low surface energy of around 31 dynes/cm. Almost nothing will adhere well enough to it to ensure a reliable, long-term repair. The usual solution is a hull replacement.
However, the use of two well-fabricated, flexible metal plates with rubber membranes between them is very clever. From what I can see, it should work.
Nicely done!
Thank you for documenting that, it can serve as a tutorial for other such repairs. The trick would be to have it done for well under the cost of a new hull.
PostPosted: Mon Mar 01, 2021 5:30 am
Thanks for your feedback Pro! We will be taking her out this weekend for a gradual test and let you know how she faired!
PostPosted: Tue Mar 02, 2021 11:08 am
Good job on the repair in a very difficult location. Looks to be stronger than the original. Perhaps a fore runner to a stronger design.
Jim
Hobie TI 2016 - Offshore rig - Outboard
Hobie Kona 2014
Hobie AI 2015 - sold
Hobie Rev 13 2014 - sold
Hobie Outback - 2008 - sold
PostPosted: Tue Mar 02, 2021 8:45 pm
Cheers Powersjr... it was that or a new hull. Will update on performance
PostPosted: Thu Mar 04, 2021 7:45 pm
Here is a video about our first full-on sail after the DIY repair.
https://youtu.be/XBSjfz_vAOk
