It is currently Wed Aug 21, 2019 3:34 am
Has anyone else had this problem?
Yes 0%  0%  [ 0 ]
No 100%  100%  [ 5 ]
Total votes : 5
 Post subject: Stripped Drain Plugs
PostPosted: Thu Sep 27, 2007 8:25 pm
When taking out the rear drain plug (next to the rudder) on my islander, I noticed a certain difficulty, and when I went to put it back in, I couldn't do so because of the holes being almost completely stripped! I ended up re-inserting the plugs with the help of a wrench, and have had to use a hand pump to drain the yak ever since... I’m thinking about installing a separate drain plug, but am wondering if it’s worth the trouble, or whether I should just stick with the pump…
I have also noticed this problem with the seat drains, but I usually leave those open, since I'll end up soaked anyways. :lol:
If it isn't broken, take it apart and fix it anyways!
Z
PostPosted: Thu Sep 27, 2007 8:52 pm
The plugs have a built in retainer -- check to see that it isn't accidentally wrapped back into the threads of the plug. This will make it almost impossible to operate. Here's an example of a wrapped up plug retainer (they're supposed to extend straight out). 8)
PostPosted: Fri Sep 28, 2007 8:49 am
I checked it, and it's actually the plastic of the hull that is shreded!
the hand pump works ok, so i'll probably stick wit hit...
thanks for advice.
Z
PostPosted: Fri Sep 28, 2007 8:54 am
When I first got my Islands I always used the drain plugs, but after breaking a rudder pin (it wasn't the main cause) and looking at how the hull had to be held to get all the water out, I started pumping and then using a sponge for the rest. Seems to be quicker, safer (AND LIGHTER)!
Kayaking Bob
PostPosted: Fri Sep 28, 2007 10:43 am
Authorized Hobie Dealer
We never use the drain's I think they could do away with them, as long as you left a hatch open for it to air. we trow a shammy sponge in the front of all the kayaks, works great!
Brad Stephens
Brad@sunjammers.com
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Sat Sep 29, 2007 8:25 am
when driving from 200' to over 5000' expanison in the ama. On the return trip the ama will suck in... if not vented..requiring continued use of the plugs. the reason I do not like to operate them is that continue use causes wear and possible misalingment. Once the threads are worn??What then...leakage...pumping
