It is currently Thu Jun 22, 2017 5:07 am
PostPosted: Tue Aug 11, 2009 8:03 pm
I have bought the Lowrance x50 DS with the thru the hull mounting kit (not actually through the hull you see :shock: ) and am looking for the picture I thought I saw somewhere of the PA with this thing mounted, along with a rod holder forward of the seat. I guess I can figure it out, but thought a little help on placement would be good. Any takers on giving a "newbie" to all this a little advise?
PostPosted: Fri Aug 14, 2009 10:14 am
Hobie Team Member
Fish finder installation on Hobie Pro Angler
http://www.youtube.com/watch?v=I-ul14Ct37Q
OEX Oceanside - Authorized Hobie Dealer
Kayak Fishing Specialists
www.oexoceanside.com
PostPosted: Fri Aug 14, 2009 10:25 am
Thank you...I appreciate the you tube video. I did mine just a little different, but am happy with the install.
Now, I just need some help reading the output of the FF. On fish id, I see lots of fish, but when I change back to normal, I don't see any fish arches...only big blobs occasionally. Have any more video learning spots for using the ds 50?
Again, thanks for the help
PostPosted: Fri Aug 14, 2009 2:15 pm
Hobie Team Member
1. Leave "Fish Id" off. It will read every bounce back as a fish.
2. I only get arches when I'm
a. - moving quickly over decent size fish (10-20 lbs)
b. - really big fish 30+ lbs
3. The blobs you see could be bait (although it usually shows up as a cloud) or plant-life.......or air bubbles in your epoxy/silicone etc..
Good luck
PostPosted: Tue Aug 18, 2009 10:09 am
I am wondering if it isn't air bubbles. I used the install kit recommended by Hobie, and felt like I had pressed it well into the marine goop. You think it possible to remove it and reinstall it?
The battery pack that come with the through the hull kit was I thought supposed to be water proof. Yesterday when the batt. level read just over 7 volts the screen went blank. Thinking it probably was the batt's, I got to the place where it was installed, and found the bag was quite wet, inside and out. I reinstalled new batt's and then put them inside a plastic sandwich bag then back i the water proof (supposedly) bag. Any comments. BTW, no great amount of water is ever in the hull. I am also considering buying a 12 volt rechargable batt. Anyone use one, and if so how did you secure it inside the hull? I am talking about a battery that is 2inches by 2inches by 6 inches.
Users browsing this forum: SRAces, Yahoo [Bot] and 4 guests
