It is currently Fri Jul 21, 2017 5:48 am
PostPosted: Tue Aug 11, 2009 8:18 am
When i first picked up my PA from the dealer. They showed me how to run and mount the rudder control. The control cable was run around the outside of the seat. Problem is i was getting alot of binding while steering. After going with a friend to a different dealer to pickup his PA. That dealer showed me a different way to run the control.
Instead of running on the outside you run it strait under the seat,in the channel.
I used to clip the control on the front of the seat. Now i clip it to the side as shown.
What this does is give the cables a gradual bend instead of the hard 90 degree bends around the seat. Doing it this way eliminates the rudder binding i was having.
PostPosted: Tue Aug 11, 2009 6:21 pm
Thanks for showing that, I will have to try it on my PA next outing.
PostPosted: Tue Sep 01, 2009 10:26 am
I've had the steering set-up changed to every configuration known, and nothing seems to work perfect. I will be trying this next, thanks for the input.
I'm more than certain a new design will be in the works for 2010. This is the only flaw I see in the PA. Going to do this modification right now, no time to waste thinking about it. Thanks!!!!!
PostPosted: Tue Sep 01, 2009 12:48 pm
It made all the diffrence in the world on mine. Mike, let me know how it works.
Users browsing this forum: No registered users and 5 guests
