It is currently Fri Jan 19, 2018 11:10 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Jun 25, 2010 11:46 pm
CBull,
:? Hmmmm...
I had a closer look again today. The frame feels a lot lighter than the Trax when wheel-less.
You're right about the hollow bearing tube but the axle tube was definitely hollow. There appear to be end caps in the 1/2" tube to give the impression of being a solid axle. :wink:
PostPosted: Sat Jun 26, 2010 7:41 am
Stringy,
Interesting, hollow it is then.
Now why would the HD cart with its hollow axle, have a higher load rating?
March 2010 Hobie Pro Angler
CBull
PostPosted: Sat Jun 26, 2010 9:03 am
It's the rating of the tires and wheel assemblies.
PostPosted: Sat Jun 26, 2010 1:05 pm
OK, so with the HD tire & wheel assembly on the standard cart frame, does this "upgraded" standard cart frame with the HD wheel & tire assembly then rate higher yet than the factory made HD cart?
CBull
PostPosted: Sat Jun 26, 2010 2:24 pm
Probably the same rating. (same tires and wheel assemblies)
PostPosted: Sun Jun 27, 2010 1:55 am
CBull,
I think the HD frame is basically the same as the standard frame. As Bob said, its the type of wheel that determines the capacity.
I'm not sure if the Trax2 with the HD wheels officially has a higher capacity but I prefer it because of:
-its versatility...being able to swap wheels to suit the terrain.
-its wider stance.
-its solid axle which is easier to re-weld if necessary ( I have re-welded my Trax1 a couple of times in 2+ years of use)
-its heavier which makes on the water insertion easier. :)
