It is currently Sat Jan 20, 2018 4:47 am
 Post subject: Size of the rear handle?
PostPosted: Mon Jul 19, 2010 1:28 pm
My last post didn't go through for some reason.
I am looking for three measurements of the PA rear handle.
Diameter of the pipe, the length of the exposed pipe and the distance from the handle to the stern of the kayak.
Thank you for your help.
PostPosted: Mon Jul 19, 2010 4:32 pm
It's about 1 1/8 inch tubing, outside dimensions regardless how tubing is measured. The rear handle is just over two inches clearance from the hull. The side handles are just over an inch from the hull.... forgot that dimension. Call it 1 1/8th clearance maybe.
Yakkingaway
Portsmouth, VA
PostPosted: Mon Jul 19, 2010 8:18 pm
Thank you. I'm going to make something to hold the transducer for a fishfinder. This is for a Humminbird 798ci SI so it has to be in the water.
PostPosted: Tue Jul 27, 2010 2:19 pm
Hi, i'm looking at a Liberator transducer mount. It fits on the front board, and will swing up easily when your in shallow water. Someone else here suggested that mount in another post.
Users browsing this forum: Bing [Bot] and 4 guests
