It is currently Sat Mar 25, 2017 5:22 pm
 Post subject: 2011 & 2012 PA14`S
PostPosted: Mon Jun 25, 2012 8:36 am
PRO ANGLER 2011 & PRO ANGLER 2012.
Anything different between the two?
What changes were made if any? ( PA-14 ) :?:
 Post subject: Re: 2011 & 2012 PA14`S
PostPosted: Mon Jun 25, 2012 9:55 am
The only change I'm aware of was the alignment notches in the Mirage Drive well to facilitate putting the Mirage Drive in.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
2012 Pro Angler 14 (owned now by a good friend)
2013 Pro Angler 14 - Dune
2015 Pro Angler 14 - Papaya
PostPosted: Mon Jun 25, 2012 12:08 pm
I could buy a 2011 PA14 and save a little money, but without the 2012 ( Alignment Notches) is this a deal breaker? Was this a big problem for the 2011 models? Thanks.
PostPosted: Mon Jun 25, 2012 12:48 pm
The alignment notches or grooves in the 2012 were added as an improvement. They just made putting the Mirage Drive in easier. The 2011 model still works just fine without those alignment groves from what I understand. Maybe someone with a 2011 PA can elaborate on the subject.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Mon Jun 25, 2012 1:03 pm
The notches makes it a little more fool proof. Without notches you have to look and see to make sure the drive is level on the lower foot area of the well. (NOTE: Not sure the termology I use would be Hobie terms, but maybe you get the drift of the content.
The bottom line is you could latch down the drive and have it out of the well and cause some damage to the foot area of the well. But you would feel a difference in the performance of the mirage drive right away and wonder what was wrong.
PostPosted: Mon Jun 25, 2012 1:17 pm
Hobie Tech / Moderator
viewtopic.php?f=60&t=12836
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Mon Jun 25, 2012 2:38 pm
Dont forget the reinforced scupper tubes too.
Users browsing this forum: No registered users and 6 guests
