It is currently Mon Jan 22, 2018 8:11 pm
 Post subject: Ocean rudder for PA?
PostPosted: Fri Aug 06, 2010 9:58 am
Does Hobie have a upgrade to a longer rudder for us in the ocean? I'm hoping that this would solve some of the PA tracking issues.
 Post subject: Re: Ocean rudder for PA?
PostPosted: Fri Aug 06, 2010 10:57 am
I bought the larger model that has greater surface area, but not much longer. I attached the smaller orginal rudder with two bolts where the shorter rudder would stick down about six inches lower in the water... Works very well, but you have to remember to lift the rudder much sooner when approaching the shallow water... I also don't force the rudder into the up position. I get out and lift with my hands. Just a thought about getting more bit for the buck... Works for me. try it you will like it. Good luck.
My bad... I did that with the outback not the PA.. sorry for mis-information.
PostPosted: Fri Aug 06, 2010 9:24 pm
No. If you don't have the newer steering drum, the update would help with rudder sensitivity.
You might experiment with a winglet for more authority, but I'm not sure how much benefit you would get from it at PA speeds. 8)
PostPosted: Tue Aug 10, 2010 11:40 am
How much of a benefit was the addition of the wing? Did it increase the accuracy of your steering? I cruise in the PA at 2-4 mph at faster speeds it tracks better due to the foward momentum. At slower speeds I get pushed off course by the swell. I may have to try the wing upgrade out.
Steve
PostPosted: Tue Aug 10, 2010 12:42 pm
I like the wing idea if it helps with the steering at lower speeds. Someone mentioned the upgrade for the steering? Is that an after market item?
PostPosted: Tue Aug 10, 2010 10:23 pm
The early PAs had a smaller steering drum and the steering was a bit twitchy. Hobie made a running change to a larger drum and has also made this available to the early boats at no charge. See your dealer for details.
Winglets work better at higher speeds. On most kayaks it wouldn't be very effective at speeds lower than 5 MPH, but on the PA, the water passing over the rudder is slightly accelerated, so a wing might still have a noticeable effect at slower speeds. Someone would have to give it a try. I mentioned it since there isn't a larger rudder available, this is a way to effectively increase the area of the rudder a small amount while retaining the original set-up.
The PA has a lot of surface area above the waterline, so wind and swells are going to have a larger effect on course heading, especially at slow speeds where rudders always have less authority.
IMO, rudder placement rather than rudder size is a significant reason for poor tracking. Additionally, the hull has weak directional stability in order to achieve excellent turning. Considering the overall design, it would seem to be an inevitable characteristic of the boat. 8)
PostPosted: Wed Aug 11, 2010 6:31 am
Roadrunner - Thanks. Where did you get the material for the wing and adhesive?
PostPosted: Wed Aug 11, 2010 10:50 am
Just be aware, the winglet works well for some people, but here in Hawaii I made 2 beautiful winglets back 3+ years ago when we were having problems keeping the AI rudder down. Both ending up cracking the rudder assembly after 5 min. of sailing and sinking to the bottom. The culprit seemed to be the chop causing the rudder to quickly try to pull up and then force down the rudder, which was too much stress for it's assembly. If you do try it, I hope you have a better experience than mine! :o :shock: :(
Oh well :)
PostPosted: Wed Aug 11, 2010 9:25 pm
I don't think that will be much of a problem since you don't have an AI or a Twist and Stow rudder, nor will you be going anywhere near those speeds. I certainly wouldn't have suggested the possibility if I thought otherwise. I have used winglets on the AI, Adventure and Oasis since 2007 with no problems.
Winglet material is Plexiglass (scraps from the local plastic shop). Adhesive is epoxy. I used a fast set to tack it and a longer set for strength. Currently I like Loctite Marine epoxy.
Here's a how-to to get you started.
viewtopic.php?p=30080#30080
The PA may require some special adaptations. For instance, the winglet can't extend beyond the back edge of the rudder. One way to solve that is with a slot in the back of the rudder to allow the winglet to slide forward in order to mount it. Once epoxied, you should have full strength. 8)
PostPosted: Thu Aug 12, 2010 9:19 am
No arguments with Roadrunner, he's our guru! :)
My winglet rudders were a thing of beauty, and I enjoyed making them. They just didn't work out for the waters and conditions I sail. And it greatly surprised me when they did failed. Then my wife had to rub it in and sail circles around me while I limped back to the launch site. :? (I've done it to her before, but that's just challenging her to stretch her skills 8) )
So, just don't go too far off shore when testing it for the first time. And enjoy!
PostPosted: Thu Aug 12, 2010 10:00 am
Thanks guys. I will post on how it works out.
Users browsing this forum: Google [Bot] and 5 guests
