pro angler leak
Page 1 of 1
Author:  mossy [ Wed May 04, 2011 2:34 pm ]
Post subject:  pro angler leak
just out of thaught me and a frine have the same problem water in the hull but not when fishing .when the p/a is stored and after a rain there has been a litttle water by the front mast in the hull anyone havethe same problem if so how to fix it ...
Author:  bboren03@aol.com [ Thu May 05, 2011 3:40 pm ]
Post subject:  Re: pro angler leak
Is it stored up right? if so it is getting through the front hatch due to the poor seal on it. On the back of it facing the cockpit I looked at mine and it had a upward curve to it, I stripped the seal off and, took tape and made a straight line and cut it with a razor blade. Put the seal back on and it helped the seal on the removable tub instantly. I was glad I looked at it and figured out the problem.
