It is currently Sun Jan 21, 2018 7:39 pm
PostPosted: Tue Jan 27, 2015 4:28 pm
Got my Hobie battery install kit today: 12 V battery in a hosing that sits in the rear hatch nicely. Should make connecting my Lowrance 4 tomorrow easy as pie. My question though, is can I use it for more?
I plan on adding an led light kit for night fishing as well. Can the battery handle both chores? I ask because the Hobie instructions say "Do NOT cut the excess power cable as it will interfere with the fish finder."
I had planned on running the wire to a box and splitting off - one power to the fishfinder and another to the led lights.
Am I seriously going to have to install TWO batteries now???
PostPosted: Tue Jan 27, 2015 8:27 pm
Yes the battery will work....Since the lights are not a "pulsating load", a steady DC current load from the LED's would not interfere with the fish finder operation.
I would make sure you use separate in line fuses for both the components, so if one happened to short, you still have the other item functional.
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Wed Jan 28, 2015 4:34 am
Thanks for the confirmation. I've never heard that shortening a wire lead would cause transducer problems. I actually would've thought the opposite - shorter wire = less impedance, etc. And one a wire stretching 10 ft instead of 12? Shouldn't matter at all.
I was considering a small distribution panel to hook everything up to but may just go in-wire and connect everything direct.
Tight lines, amigo
PostPosted: Wed Jan 28, 2015 10:17 am
YOu will be happier with two seperate batteries for that operation. Good luck
PostPosted: Wed Jan 28, 2015 11:40 am
How about the Hobie kit and a micro Power Pole? I was hoping to use one battery for both the fish finder and the Power Pole.
