It is currently Sun Jan 21, 2018 12:44 am
PostPosted: Fri Jul 01, 2011 6:08 am
Around here on the Georgian bay, we like to gig in the spring for rainbow ,white fish and lake trout ,we anchor in 20 to 60 feet's of water in front of rivers and use chum ,send down right under the boat with homemade chum can rigs.The tricky part is to stay over you,re chum pile in the wind and wave as the fish start coming in you down want to loose anchor .I welcome any advise and suggestions as what will be the best anchor weight and rope length and diameter for this boat .Thanks new owner.
PostPosted: Sat Jul 02, 2011 12:53 pm
Check out this post of mine. It might work for you.
viewtopic.php?f=26&t=32599
PostPosted: Sat Jul 02, 2011 1:57 pm
Thanks for the info, i will give it a try .Have you try using a chain instead of a bungee as mention bellow in you,re tread ? just wondering witch set up is best. :?:
PostPosted: Wed Jul 06, 2011 8:43 am
No point in using a chain. The idea is to keep the anchor line as vertical as possible. In calm weather I'll go with just the cam cleat. If there are waves from wind or boats I'll employ the bungee to keep me from walking off of my spot.
