It is currently Wed Nov 22, 2017 8:38 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: I-pilot 55 on Pro angler
PostPosted: Thu Jul 28, 2011 8:33 am
I would just like to know if anyone has used a bow mount on there PA? I am looking at an i pilot model from Minn Kota.
Thanks for any advice in advance
PostPosted: Thu Jul 28, 2011 10:21 am
There are a few on Youtube installed on Kayaks smaller than the PA. It's the best way to move the PA if you have the$$$. Just do it, you'll make everyone here jealous.
Unlike the other Kakak specific motor/steering systems, it will always be a wireless trolling motor that can be used forever. With a #55 you could do 7+mph, and only drill 4 holes in the PA not 20.
PostPosted: Sat Jul 30, 2011 7:52 pm
Well as if today I have mounted the bow mount on the stern and plan on testing it out tomorrow. Pics to follow.
PostPosted: Thu Aug 04, 2011 5:40 pm
Looking foward to reading more about this, please don't forget to update us...Thanks!
PostPosted: Fri Dec 09, 2011 10:03 pm
um about those pics......
PostPosted: Fri Dec 09, 2011 11:46 pm
Look for my post..... Powerdrive v2 on pro angler.
PostPosted: Sat Dec 10, 2011 6:00 pm
Just waiting on the 2012 model to be released, and the Spring to get it on the water.
I'll post pics or maybe a VIdeo
PostPosted: Mon Jan 16, 2012 12:14 pm
very interested in this
PostPosted: Mon May 14, 2012 7:41 pm
Finally got the I-pilot installed and did a quick test run. Very very happy with it. Might not look real pretty as a bow mount, but it sure does whats advertised.
The Spot lock is my favorite feature so far: being able to hold my position and re-tie a lure or fight a fish without being blown half way across the lake or river is amazing. It holds you within 5 feet of the spot you choose in the strongest of winds or currents. Priceless!
The record a track feature is also great : you can follow and record a contour line around the shoreline and go back and troll it over and over trying a different lure on each pass.
Can't wait to go out again.
Would I do this again. Without Question
PostPosted: Tue May 15, 2012 10:43 am
Here's a couple of pics...
Fixed image links
PostPosted: Tue May 15, 2012 11:23 am
Have you thought of shortening the shaft? You can carefully remove the armature and unclip the brushes to remove the wires from inside the shaft, then you can cut it to length. How fast does the 55 lb. thrust pull the PA?
PostPosted: Tue May 15, 2012 11:52 am
Dry Bones
Not sure if I want to cut the shaft because I might want to use it on an other boat.
Got it up to almost 7 mph against a strong headwind.
PostPosted: Tue May 15, 2012 12:28 pm
What prop are you using?
PostPosted: Tue May 15, 2012 12:58 pm
Sorry I might have have misquoted the speed not sure if my Humminbird gps was set to MPH or KPH. I will check out the max speed on my next outing and repost, I was playing with the features more the firsts time out than doing speed trials :D
Tom it is just the standard prop that comes with the Riptide
PostPosted: Tue May 15, 2012 1:31 pm
I wondered, as I've found that a 55 lb thrust motor will not push the PA any faster than a 30 lb thrust motor if they're both running the same prop. Either will spin the factory props at the same maximum RPM.
The only way to get more speed out of the larger motors is to move to a prop with a higher pitch. Otherwise you're not gaining anything. The PA will indeed move at more than 7 MPH, but not with the factory props offered by MinnKota or Motor Guide. Those props are designed to push 800 lb+ vessels. Thus the shallow pitch.
My guess is that if you switch to MPH you're going to find that you're running between 4 and 4.3 MPH.
