It is currently Wed Jan 17, 2018 7:52 pm
PostPosted: Mon Oct 31, 2011 10:23 am
I cannot fit my pro angler in my shed and use the garage for cars. So I need to know what is the best way to store my pro angler outside? I do have a jet ski/kayak trailer. Am thinking of making a lean too for the kayak. please let me know what I need to do.
I also have a Hobie Mirage tandem that I need to store.
thank you :?:
PostPosted: Mon Oct 31, 2011 11:25 am
Hobie Tech / Moderator
have you looked into a Harken Hoister system? (perhaps you can have both kayaks in the garage 'over' your car?) Link: http://www.harkensport.com/cat/hoister.html
If leaving it outside, its best to buy a cover - and don't leave it flat on the ground - invest in a cradle system (otherwise you will dent the bottom over time)
PostPosted: Thu Nov 03, 2011 7:51 pm
I just purchased a PA in October, and only got to try it out for and couple of hours. May not get to use it at all until next spring because of other events.
In the mean time I installed a RacorPro PHI-1R Pro HeavyLift to my garage ceiling, it holds up to 250#.
The one thing you need to do is replace the lag bolts (they looks closer to screws) with some quality 5/16" lag bolts from your local hardware store.
Amazon has the best price for the lift.
Good luck
PostPosted: Fri Nov 04, 2011 6:46 am
I have the Harken sysem and it's very good. Well designed and executed
