It is currently Thu Jan 18, 2018 6:48 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Oct 06, 2012 4:04 am
Then I study a simple resolution and which should work correctly.
As I'm sure PEHD lets through waves, I sharpened in an end the same form of the plate of protection Hobie..
Then I embedded well the sonde with the foam high specific gravity so that it does not move in its accommodation, but a little lower than the first try..
Then I heated up with a thermic warmer, PEHD took the form of the transducer:
Then I screwed on screws thoroughly.
So the sonde is protected, both sides are clear and water circulates freely.
Have to see on water but I trust about it...
François - French Hobie fishing team - Compass seagrass
PostPosted: Sat Oct 20, 2012 2:32 am
Try this morning. Very disappointed because it loose more than 50 % of side picture but what I had not realized before, that palms create turbulence and picture is crinkled. :evil:
Therefore for me the transducer hole doesn't fit for Side and Down views (Lowrance structure scan should not work as well).
I turn back and will stuck the transducer on front:
