It is currently Wed Nov 22, 2017 12:35 pm
 Post subject: H Bar location help???
PostPosted: Sat Apr 21, 2012 9:44 pm
Since HBars are on backorder. Does anybody know where to place a fishfinder on the front accessory boards so it will not interfere with HBar when it finally comes in?
PostPosted: Sat Apr 21, 2012 10:51 pm
I placed mine on the bar. It was interfering with Hbar. However, if you have the madfroggear mod boards, you would have adequate room.
2011 HPA
2006 Wildy Ride 135
PostPosted: Sun Apr 22, 2012 7:09 am
If you use a RAM mount, you can position the mount either in-between the H-Bar uprights, or just aft of the rear upright. The RAM will allow you to swing the FF out and away from the bar itself.
PostPosted: Mon Apr 23, 2012 7:13 pm
I mounted my H bar based on using the original mount for the side board. From the photo I am posting, you can see the front inside bolt is the original for the side board. I used a longer bolt is all. This put the H-bar forward and gives me maximum standing area. The rearward H-bar mount is then far enough forward that my fish finder can mount behind it and still pivot enough to fold down when I am traveling.
I am using the Mad Frog side boards, but the hole placement will fit on the stock boards too.
PostPosted: Sun May 06, 2012 11:41 pm
are you using the orignal mounting hole for the boards on the front bolt?
you hookem and i will fry um
PostPosted: Wed May 09, 2012 4:10 am
Thanks for the info. will mount my mad frogs tomorrow
PostPosted: Wed May 09, 2012 7:57 pm
You will need to remove the rod tubes to mount the mad frogs. Then, in order to reinstall all four screws for the rod tubes, you'll need to drill a slant hole for a screw driver blade to get in there for that last screw. Look close at my photos and you will see a hole. It isn't big, I used a smaller bladed screw driver to get in there.
PostPosted: Wed May 09, 2012 7:59 pm
I did use the original mounting holes. When you hold the original side board up to a mad frog board, they are the same hole pattern.
Users browsing this forum: Bthomas and 5 guests
