It is currently Sat Mar 25, 2017 3:20 pm
PostPosted: Mon May 28, 2012 10:54 pm
....... the issue is I am 5'10" and I know all the Hobies fit me, but my mate is way huge. Guessing 6'10" with crazy long legs .. My query is, which model will be the easiest to adjust from short to long. My guess is that the Revo, OB, PA 14 and PA 12 will all have the same distance between seat and peddles. I normally have my peddles adjusted to position 2 ..... so there is a heap of easy adjustment there, but the PA seats may have adjustment as well. I am trying to get a Demo ..... but no 12's here yet. Any thoughts from the "think Tank " ?
PostPosted: Tue May 29, 2012 12:22 am
Sounds like u need a PA 14 with the adjustable seat mod
PostPosted: Tue May 29, 2012 4:38 am
PA 14 has the most length between the seat and the peddles. Also the peddles themselves have the 6 different adjustment settings.
Matt Baden
http://www.thehobielife.blogspot.com
AFTCO, Kanan Lures, Astral Buoyancy and Alltackle.com Pro Staff
2012 Yellow Pro Angler 12 and 2014 Pro Angler 12
PostPosted: Tue May 29, 2012 5:14 am
Don't share, get TWO. Good luck
PostPosted: Tue May 29, 2012 5:37 am
I could trade him in on someone shorter.
PostPosted: Tue May 29, 2012 8:17 am
Your weight difference is also an important consideration. A boat like the Revolution will handle quite a bid differently if there is a significant amount of weight in it. Larger people tend to find the Revolution to be a bit less stable than average sized people or smaller people.
The Pro Angler's (especially the 14) have plenty of capacity. I'd start there.
PostPosted: Tue May 29, 2012 6:19 pm
I would suggest putting in the sliding seat modification and then purchasing a PA 14. If you are going to share, I would think that this would allow you both todo so until you purchase the second PA.
Regards...
